09-22-2017, 05:08 PM | #21 |
| Re: Options for vertical front shocks? Options for rear setup?
It's not that much longer. Looks like it's supposed to have them.
09-22-2017, 05:33 PM | #22 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Options for vertical front shocks? Options for rear setup? |
09-22-2017, 05:36 PM | #23 |
09-22-2017, 08:04 PM | #24 | |
| Re: Options for vertical front shocks? Options for rear setup? Quote:
There are some shorter trailing arms that may work. The 1/12 clone FEIYUE FY03 uses 96mm arms whereas the TH are 116mm. I have one of them and a spare set of arms, too. The only problem is they use m2.5 hardware. | |
09-24-2017, 08:43 PM | #25 |
09-24-2017, 08:59 PM | #26 |
Quarry Creeper Join Date: Sep 2010 Location: appleton
I bought it but never ran it. Ended up buying a GCM plate before I could try ir Sent from my SAMSUNG-SM-G935A using Tapatalk |
09-24-2017, 09:14 PM | #27 |
09-24-2017, 09:21 PM | #28 | |
Rock Stacker Join Date: Jan 2016 Location: Australia
I ran yeti length trailing arms in mine for a while. It did seem to provide some more articulation in the rear, but because of the longer wheel base I noticed the TH got hung up on stuff more often than when I ran the stock length trailing arms. I'm more of a basher than anything else, and no suspension tuning expert, but I couldn't pick any improvement in high speed handling either, so put stock units back on.... | |
09-24-2017, 09:23 PM | #29 |
09-24-2017, 09:28 PM | #30 | |
Just because I have several sets of Yeti/SMT TArms. It will stay stock for several months. | |
09-24-2017, 09:44 PM | #31 | |
It is a simple option I never thought to try with the TH. Post up a pic if you do a mock-up. I a man very curious to see it done. Edit: you did that to bypass the difficult access to the Exo's guts? | |
09-24-2017, 10:00 PM | #32 |
I got the Exo as a roller with a hack job Wraith cage attached. Good deal at the time... Now the Exo cages are sky high. I had this body with almost the perfect wheelbase I figured it make a cool SCT styled basher. So far so good once I've gotten CVDs in it.
09-30-2017, 03:32 PM | #33 |
Well. I swapped the ESC plug over to deans and charged up a 2s lipo. Took it for a spin around the yard and the 2 speed to set up great. But it kept rolling over and I gave it a closer inspection. It seems the front diff is toast. Neither wheel spins when throttled and the driveshaft is spinning. Looks like my killer deal may be on par after the repair. Oh well. It is clean though.
10-02-2017, 04:31 PM | #34 |
The TH diffs are pretty rugid, so unless someone ran them with the bearings extremely worn for a while they are likely fine. Check the grub screws on the front driveshaft, they like to loosen up after initial assembly as everything "takes a set". |
10-02-2017, 05:35 PM | #35 | |
Forgot to update that. Found both screws loose. I was doing body panels and was gonna do some sort of thread. | |
10-16-2017, 05:26 PM | #36 |
The set screws on the front drive shaft break loose regularly for me since dropping the 10.5T sensored motor into my rig. It is a huge PITA when out on a run. Wish there was an upgrade.
10-16-2017, 06:06 PM | #37 | |
I was thinking that it was a poor setup. I didn't document and am thinking 'out loud', but will an Axial shaft fit? That way a pin can be ran all the way through it. | |
10-16-2017, 08:27 PM | #38 |
| Re: Options for vertical front shocks? Options for rear setup? I have no idea. Can't say I have tried to fit one. If it does it would be the first I have heard of it. When MIP made drive shafts for the TH, they only made the rear piece because apparently the front lacked the space required to fit one.
10-17-2017, 12:51 AM | #39 | |
Sent from my SAMSUNG-SM-G935A using Tapatalk | |
10-29-2017, 09:25 PM | #40 | |
Pebble Pounder Join Date: Jun 2008 Location: Carmichael
| Re: Options for vertical front shocks? Quote:
Sent from my SM-G955U using Tapatalk | |
Options for vertical front shocks? Options for rear setup? - Similar Threads | ||||
Front axle options? | BDR | Axial XR10 | 12 | 03-16-2015 01:46 PM |
Vertical front shock angle | photon_trap | Vaterra Twin Hammers | 13 | 06-05-2013 09:08 PM |
Front shock options? | Baja Bandido | Vaterra Twin Hammers | 2 | 05-13-2013 04:33 PM |
spring options for t-maxx shocks or what shocks to use? | SmokeScream | Axial AX-10 Scorpion | 2 | 08-13-2010 01:02 PM |
AX 10 front axle shafts options, please! | Jeep-Power | Axial AX-10 Scorpion | 8 | 06-10-2009 02:58 PM |
