05-10-2018, 03:20 PM | #1 |
Newbie Join Date: Apr 2018 Location: Temple
| Yeti links on TH?
I want to lengthen the wheelbase of my car, mainly because i think it will help it climb hills better. if i use Yeti links, will it change my shock angle? I’m guessing that i will need heavier spring because of the increased leverage of longer trailing arms? And is a Yeti driveshaft the proper length with these arms? Any advice is greatly appreciated!
05-10-2018, 03:43 PM | #2 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Yeti links on TH?
Blue Monkey RC used to offer a +1 MIP driveshaft kit that worked with the Yeti Trailing arms. That is what I used on my TH with the extendended WB. I believe many guys have used the Yeti MIP shafts as well. It may be they had to slightly modify them, but I cannot remember what was required. You might check out bilinvic’s thread. He did this recently and puts together excellent build threads. bilinvic's Twin Hammers Last edited by smog; 05-10-2018 at 03:46 PM. |
05-10-2018, 04:35 PM | #3 |
I bought a aluminum yeti d-shaft, i’m assumng that i can cut it down if it’s too long
05-10-2018, 04:45 PM | #4 |
| Re: Yeti links on TH? |
07-13-2018, 07:02 PM | #5 |
Rock Stacker Join Date: Dec 2015 Location: Kahnawake
Yeti links and stock shocks work fine.
07-17-2018, 02:21 PM | #6 | |
| Re: Yeti links on TH? Quote:
X2 May need to increase spring rate and oil thickness to help handling. | |
Yeti links on TH? - Similar Threads | ||||
Yeti XL Titanium links | Erik D_lux | Axial Yeti XL | 5 | 03-06-2015 06:13 AM |
Yeti XL Titanium links | Erik D_lux | Chassis and Suspension | 0 | 03-05-2015 09:19 AM |
