Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: First ever build
Old 01-20-2020, 06:36 AM   #1
Default First ever build
Hello RC Crawler people!
I'm currently in the process of building my first ever kit. As you may have guessed, it's a twin hammers .
The vehicle is mostly assembled as it sits waiting for finishing parts to arrive. I will be using this as a bashing rig on grass, forest trails, gravel pits. It does not need to be waterproof. Hoping for good run times and durability.
If someone could look over the parts list and let me know if I'm missing anything, or any recommended upgrades, that would be great. Recommendations for a RX/TX combo?
Twin hammer, locked into 2nd gear
Scorched parts bellcrank steering + upright shocks + hardware
Scorched parts 2s battery holder
Scorched parts esc/rx relocation
Scorched parts anti-squat truss
Gmade RSD 80mm shocks - these are on back order with no ETA. Any ideas for another option? I saw some 75mm proline crawler shocks that looked good.
Mamba X 25.2V WP ESC +1406-3800kV Motor Combo
Savox SA-1256TG w/ TLR1557 25T servo horn
25T 48P 1/8" pinion
great.dividers is offline   Reply With Quote
Old 01-22-2020, 11:34 PM   #2
Default Re: First ever build
I would say that your list pretty much covers all of the bases for a good start..For shocks you could always grab a pair of used SCX 10 and limit them internally..It works well enough and they are everywhere pretty much.I kept the front diff unlocked and just filled it with 1,000,000 weight diff fluid which works pretty well for me..
I also purchased the scorched gear shifter.It works perfect in place of the servo..In second gear with a 28T it's almost too fast and I am thinking of going down to a 22T,more so for a good slow speed crawl in low gear..I have the same motor as you which I really like
xv-townboy is offline   Reply With Quote
Old 01-24-2020, 05:00 PM   #3
Looks like you got all the bases covered. Glad to see others still building kit twin hammers.
meatmonkey is online now   Reply With Quote
Old 01-27-2020, 12:16 PM   #4
What batteries are you using? How much run time? I can't decide what to go with.
I'm buying shorty HV 2S lipos for a racing truck. 120C 5500mAH. I could use them for my twin hammers as well I think. Or I try running it on 3S. I think I would have to drop teeth on the pinion though. Maybe around 20? I still plan on keeping it locked in 2nd gear for now
First ever build - Similar Threads
JackedDriver's R1 Build (non-specific purpose / just wanted a good build) JackedDriver G-Made Crawlers 12 01-12-2016 07:59 PM
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) Irishchamp 2.2 Scale Rigs 45 10-09-2014 10:26 PM
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ 53 willys General Crawlers 108 11-28-2011 12:42 AM
RcBros LCC Build, Hi-Res pics & More Build!! RcBro Team Losi Comp Crawler 30 06-03-2009 07:26 PM
