| | #1 |
| ... Join Date: Sep 2005 Location: USA
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jun 2008 Location: Ironton
| do you have the motor specs? post on here? |
| | #3 |
| This is the 50T Modified Fireball Rock Crawler Motor from Venom. FEATURES: Vented alloy heat sink to reduce unwanted heat build-up and increase longevity Pre-wired bullet plugs Factory installed capacitors Dual ball bearings High power brushes INCLUDES: One Venom 50T Modified Fireball Rock Crawler Motor REQUIRES: ESC designed for rock crawler SPECS: Can Length: 53mm (2.09") Can Diameter: 36mm (1.42") Shaft Length: 10mm (0.39") Shaft Diameter: 3mm (0.12") |
| | #4 |
| Order a few more of these and a couple 55T's as well. |
| Thread Tools | |
| Display Modes | |
