| | #1 |
| RCC Addict ![]() Join Date: Dec 2006 Location: RENO
| CKRC "Twister" High Torque Brushed Crawler Motors Take your performance up a notch with the new "Twister" line of precision built Hand Wound motors. When you need more Power, Torque or drag brakes a basic brushed motor just wont do. The "Twister" features: Crawler Specific Hand-Wound Armatures – Our twister armatures feature a hand wound wind with specific wire sizes developed for today’s high-output LiPo or Ni-MH batteries. All armatures are soldered using high-tech solder and then are epoxy coated with the latest state-of-the-art epoxy resin. All armatures are then pro-spec precision drill balanced and the commutator is diamond trued. All armatures are stamped with wind. ** Laydown Brushes & 9mm comm - Maximizes torque. ** Dual Magnet Can – The can features high-power FB9 wet magnets. ** Onboard Capacitors – Helps eliminate unwanted radio interference caused by electric motors. ** Dual Ball bearings * *Fully Adjustable timing * *Heavy springs for consistent drag brake These motors build more torque below 1000rpm than any mass produced crawler motors maximum torque at any rpm! Our new line of motors is available in 35, 45, or 55 turns. Check them out ***HERE*** www.ckrccrawlers.com |
| Sponsored Links | |
| | #2 |
| Team Hardkor Crawlers ![]() Join Date: Jul 2008 Location: appleton
| count me in |
| | #3 |
| Hateraide ![]() Join Date: Dec 2008 Location: Mission BC
| SICK!! i really need some motors might have to pick one up Last edited by Code454; 11-13-2009 at 05:51 PM. |
| | #4 |
| Pebble Pounder Join Date: Jun 2008 Location: Mesa
| I could use one! Thanks for the chance |
| | #5 |
| Quarry Creeper Join Date: Jan 2008 Location: siloam springs, home of the Mid West Challenge 2010
| If I buy 1 at a time for my bully would tha screw anything up? I sound like such a NEWB |
| | #6 |
| that would be fine. |
| | #7 |
| Cool thanks |
| | #8 |
| Pebble Pounder Join Date: Sep 2009 Location: Norway
| got my 35T Twister mounted it and my new FX-r PRO esc in my SCX10 yesterday, and WOW what a beast ill never go back to BL power for my Scale/Crawler needs but one Question, is this motor the same as Holmes Hobbies motors? a friend of mine has the 30T HH motor and it looks the same picture perfect match:p prolly something under the hood that is made to each vendors specc but they look excactly the same:p |
| | #9 |
| Quarry Creeper Join Date: Dec 2008 Location: Dalton
| How many RPM's per volt on the 35t's? |
| | #10 |
| 1565 rpm per volt for the 35t |
| Thread Tools | |
| Display Modes | |
