Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Vendors Electronics
Thread: 5 Pole Brushed Motors!
Old 12-23-2005, 05:23 PM   #1
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Default 5 Pole Brushed Motors ready for rewinding
Cant find a lathe motor? 5 pole, 550 can brushed motors for sale. Intro price of $6 each plus shipping.
specs:
7.4 oz / 209 gram
1/8 inch shaft diameter / 3.17mm
11 mm shaft length
25mm mounting pattern
3mm bolts
2.4" / 60.0mm can length
1.46" / 37.25mm can diameter
ARMATURE- fits in mag mayhem can, comes stock as 39 turn single
armature diameter, .905 inch
armature length fiber washer to washer, 2.08 inch
armature length no washer, 2.03 inch
standard speed control works for them
basically a standard 550 motor.
Any questions just post up.
JohnRobHolmes is offline   Reply With Quote
Old 12-23-2005, 05:40 PM   #2
Do you think they have more torque than a lathe motor?
Cubman is offline   Reply With Quote
Old 12-23-2005, 07:21 PM   #3
Cubman- The more poles, the more torque. Lathe motors have 3 poles
JRH- I'm interested, do they have the same bolt pattern? Weight? Diameter? Can length?
CustomCrawler is offline   Reply With Quote
Old 12-23-2005, 09:00 PM   #4
Hey JRH, you got PM.
Old 12-23-2005, 09:06 PM   #5
specs updated.
Old 12-27-2005, 11:19 PM   #6
looks like these babies will need a rewinding! lathe on 6 cells still a bit faster and more grunt than these 5 poles on 12 cells. Darnit!
Tested in a txt with 9 tooth pinions and LST tires. Im gonna get these suckers to work! I will try 14 cells before rewinding. I bet they would get a really long runtime if left alone, but need a good voltage to even get powerful.
Old 12-28-2005, 08:40 AM   #7
today I am going to try and find some bearings for these babies. even if the motor is $11 with bearings, I still believe that they will make killer project motors. I will make a teardown and buildup thread later tonight
Old 01-04-2006, 09:36 PM   #8
First post is up to date. The motors shipped in today and are ready to sell.
Old 01-05-2006, 05:49 AM   #9
Get off my lawn!
microgoat's Avatar
Does the shaft have a flat spot for the pinion or will I have to whip out the Dremel?
microgoat is offline   Reply With Quote
Old 01-05-2006, 07:07 AM   #10
Good question. There is no flat spot. It might not be necessary, but it is an easy fix.
Old 01-06-2006, 04:19 PM   #11
how much will shipping be for 2X to long island, NY??
seraphim is offline   Reply With Quote
Old 01-06-2006, 04:45 PM   #12
how fast do you want them? I can do 2-3 business days for $5. I don't have any wire on hand for rewinding, but radio shack does
Old 01-22-2006, 08:06 PM   #13
Get off my lawn!
microgoat's Avatar
Default It's motoriffic!
I got my sample motor from Johnrob, and made a pretty good go of it. The 5-pole arm fits the Mayhem can just fine and it spins very smoothly. I'll post details in the tech section.
Good find Johnrobbie
Old 03-11-2006, 03:13 PM   #14
bumpity bump for all of those who cant get lathe motors right now. I have plenty in stock and will ship 2-3 day priority for $5.
Old 12-19-2006, 10:17 PM   #15
Just had a guy use these motors in his clod on 6 cells at the last comp, and everbody was very impressed! So, we can move this to the 6-18 cells catagory
Still got plenty, still $6 each. These puppies are slooooow and torque-ee
Old 12-20-2006, 04:44 AM   #16
I lost my vendor privileges
i will agree with that. bought some from another company. sorry dude. before i realized that you had them. anyway they are ballzy. running 14.4 thru mine slow still but unstopable.
clodstall is offline   Reply With Quote
Old 12-20-2006, 07:34 AM   #17
JRH,
Let me know I'll take 6 of these bad boys. Need to build up my parts supply.
pureadrenalin is offline   Reply With Quote
Old 12-20-2006, 11:06 AM   #18
I wanted to let everyone know that if you plan to use one of these on a TLT, then be prepared for a SLOW vehicle. I picked one up this weekend to try on my BMVII (Evader tranny geared 88/15, 7-cell 2/3A pack with 2.2 Masher 2Ks) and while it has a lot of torque, it's a bit too slow for me with my current setup.
If you plan to use this on a TLT and want some wheelspeed as well, you had better figure to use at least 10-cells or more.
bugman72 is offline   Reply With Quote
You may edit your posts
