MOA Dig Controller Use a three position or linear channel to operate front and rear dig on your Motor Over Axle crawler. The goal when building this was to make it as light as possible while still providing full functionality. ** This is a recent picture of the controller. It shows how I build them these days: http://i.imgur.com/nBjnbC3.jpg These pictures show how I built them at first. Still valid as you see what is going on inside. http://i181.photobucket.com/albums/x...e/DSCN0722.jpg http://i181.photobucket.com/albums/x...e/DSCN0720.jpg http://i181.photobucket.com/albums/x...112146AM-1.jpg http://i181.photobucket.com/albums/x...e/DSC_4625.jpg http://i181.photobucket.com/albums/x...e/DSC_4622.jpg MOA Dig Controller Part No. DIG3 $60 plus shipping |
I´m so sorry. I confused my post. |
Nice drawing - you have some skills! The drawing is mostly correct, it just leaves out the electronics which are covered in heat shrink you see on the wires that plug into the receiver. |
Does your dig short the motor or lock it |
The circuit works to put a short across either the front or rear motor and it disconnects the ESC output from that motor, or it feeds the ESC to both motors. Did that tell you what you were asking about? |
If you activate the front Dig, will the rear tires spin or are they locked on place, sorry i had sent you a different private message before i read you answer on here |
That's okay Juan, I'll just repeat my answer here for completeness. How hard the dig locks up the wheels is a function of the motor, gearing, drive train friction and wheel traction. My dig works in the same manner as many other dig switches but (probably - depends on what they used) uses a somewhat larger relay and will therefore have a slightly better braking action. I can't say for sure that it will work better in a way that is enough for you to notice. When testing the system on my bully, if the surface isn't super grippy, the rear locks up totally. If the surface has lots of sharp edges and the tires dig in, the locked wheels will still turn a little. Hope that helps! |
It all depends on the motor (and gearing/drivetrain) , how good it locks up. A cheap integy you won't have a very good locked motor because it has weak magnets, springs, winds, etc A quality handwound (such as a brood or hh torque/crawl master) you'll have a good locked up moto because it has a nice strong magnet and springs, and have a good windings which makes a nice mag field At least the way these type of dig switches work. |
Trade You a Punk Dig for it "thumbsup" |
Re: MOA Dig Controller not to be rude but have you sold any of these things yet?? Oh and what is the weight of it? Thanks Grunt |
Re: MOA Dig Controller Quote:
I don't have a scale, but I would say the weight is about 3/4 of the weight of a metal geared servo. |
Re: MOA Dig Controller ok cool thanks, and im the complete opposite i dont want two esc's i would rather run one. |
Re: MOA Dig Controller im confused about your question or even statement? |
Re: MOA Dig Controller ahh i see lol i will soon or later but have no funds right now, im trying to get a xr10 rig ready this winter, so i can comp with the family this summer. edit whats do you think is lighter your dig unit or a micro sidewinder? |
Re: MOA Dig Controller I expect the micro sidewinder is lighter. |
Re: MOA Dig Controller |
Re: MOA Dig Controller Looking at the pictures, it looks like the motor leads have clear plugs on them? So they dont "need" to be soldered on. I have an XR10 on the way without a dig unit. Someone here reccomended you and this looks great. |
