03-29-2012, 06:44 PM | #1 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Team Brood Frenzy Mini-Motor!
A more budget version for your MRC or other mini crawler. Basic specs 22 Turns (2s recommended, 3s at your own risk) Machine Wound Replaceable brushes Non-Adjustable timing (set at zero) Bushings Installed Capacitors These work good with the stock gearing, but really come alive with the gearing mod for the rc18t spur. Best of all....pretty cheap...$20! Order here.... Frenzy 22t Mini-Motor, Team Brood Racing When these are gone....they are gone! Later EddieO |
04-12-2012, 09:47 AM | #2 |
Newbie Join Date: Jan 2012 Location: Gzira
| Re: Team Brood Frenzy Mini-Motor!
What is the size of the motors ???? 380 ? Cause my novak brushless went out and i think i will make motors brushed 1!! Thanks your follower Chris Malta |
04-12-2012, 09:47 AM | #3 |
04-12-2012, 10:11 PM | #4 |
These work in the Losi MRC....they are basically a 370 or so...they do benefit from a bigger spur gear, which you can read about the Spur gear mod in the MRC forums. Later EddieO |
05-29-2012, 07:37 PM | #5 |
Pebble Pounder Join Date: Nov 2011 Location: Fresno
370 ish? Would they work as an option in the Redcats?
05-30-2012, 08:00 AM | #6 |
Some would label it that....they are appx 24mm in diameter and about 32mm long or so not counting the shaft. I am not super familar with the redcat, so I am not sure what its stock motor is. Later EddieO |
Team Brood Frenzy Mini-Motor! - Similar Threads | ||||
Team Brood Anarchy Mini Motor Preorder! | EddieO | Vendors Electronics | 61 | 10-13-2011 04:41 PM |
Team Brood Anarchy Mini Motor Preorder! | EddieO | Losi Mini-Rock Crawler | 2 | 06-22-2011 01:53 PM |
