01-04-2013, 09:49 PM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
| Tziworld Beefy Winch Tziworld Beefy Winch Operating Voltage: 2s-3s Lipo (higher voltage may reduce motor life - replacement parts avaialble) No Load Line Speed: 26sec/m 3.84cm/sec (theoretical - will update with real world testing soon) Stall Torque: Up to 45kg / 100lb dependant on controller and voltage. Size: Similar to a standard size servo - will fit most servo brackets Price: $120au + post. Order your Beefy Winch here Companion products available soon.... Bracket for rear mounting on SCX chassis. Bracket for front SCX mount including steering servo mount. Winch Controller V2 Replacement / Upgrade motors & gearsets Testing video... Last edited by Tzi; 09-24-2014 at 11:57 PM. |
01-04-2013, 11:15 PM | #2 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
| Re: Tziworld Beefy Winch
Awesome work mate and it looks great Last edited by pajey; 01-05-2013 at 04:06 PM. |
01-05-2013, 05:34 AM | #3 |
Pebble Pounder Join Date: Dec 2010 Location: UK
Available for UK ?
01-05-2013, 03:31 PM | #4 |
Yes, we can post to UK. Just pick whichever store has the currency that offers you the best exchange rate. |
01-14-2013, 09:30 AM | #5 |
RCC Addict Join Date: Apr 2011 Location: San Diego
This includes a servo winch controller? Expected release date?
01-14-2013, 02:27 PM | #6 |
At this stage it comes with no controller. Later, we will release a new controller for it, but for now it does not. The original servo board can be included if you like, but it will require modification to use as a winch controller. |
03-04-2013, 02:18 PM | #7 |
5 winches currently in stock.
03-04-2013, 03:29 PM | #8 |
I had not seen this finished piece before! Excellent looking product for sure. I may have to contemplate picking one up.
03-04-2013, 07:32 PM | #9 |
Just got rear brackets in stock too... |
03-05-2013, 09:51 PM | #10 |
Rock Crawler Join Date: Oct 2010 Location: Nor Cal
more info please! more pictures of actual product on a working rig.
03-09-2013, 10:56 AM | #11 |
Pebble Pounder Join Date: Dec 2012 Location: Orlando
(pre)ordered!
03-12-2013, 06:56 PM | #12 |
Dimensions are now up...
03-27-2013, 10:09 AM | #13 |
1 left from this batch ready to post. More on the way... |
03-27-2013, 11:39 AM | #14 | |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
| Re: Tziworld Beefy Winch Quote:
I cut my own rear bumper mount holes in the mount, it didn't come that way. Front dual servo mounts and TZI winch forward, steering servo behind it A different truck, same dual servo mount shoved into my Toyota build Please excuse all my waterproofing goop | |
03-27-2013, 12:31 PM | #15 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
Can't wait to see more pics of these. So am I correct thinking I can also use hey ok controllers in this winch? |
03-27-2013, 03:58 PM | #16 |
I did, but TZI has winch controllers also
04-01-2013, 06:11 AM | #17 |
How much length of what diameter wire/cable/string does the spool hold while still working well?
04-01-2013, 05:35 PM | #18 |
It depends on the thickness of rope used. During testing I was determined to max it out, so needed the best cable I could get. After some testing of various ropes, I settled on MadDogRC winch rope. The spool will fit between 3m and 4m of The MadDogRC winch rope. Obviously you can put more on by using thinner rope, but it could break under super heavy load. (20kg+) Regardless if the winch drum is full or empty, the winch will still work plenty strong enough |
04-02-2013, 10:52 PM | #19 |
Mine is now sitting in its final position, I redesigned everything specifically for this piece. I'm already so impressed with the unit, can't wait to make it do work! |
04-05-2013, 10:18 AM | #20 |
When will this be back in stock? I would like to get one to try it out.
Tziworld Beefy Winch - Similar Threads | ||||
Tziworld Beefy Winch Controller - Now With Video!!! | Tzi | Vendors Electronics | 42 | 09-07-2014 05:29 PM |
New Tziworld Winch | Tzi | General Crawlers | 37 | 09-25-2013 11:44 AM |
New Tziworld Winch | Tzi | Electronics | 35 | 09-23-2013 10:04 PM |
*** GIVEAWAY *** Tziworld Beefy Winch Controller Giveaway... 2 Chances to win!! | Tzi | General Crawlers | 67 | 07-21-2012 10:26 AM |
New beefy winch controller I've been testing | War Pig | Electronics | 5 | 04-01-2012 01:54 AM |
