Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Electronics
Thread: KMS winch's all in one place
Old 04-16-2014, 06:18 PM   #81
KMS
KMS's Avatar
Default Re: KMS winch's all in one place
We have another new Hobby shop ,selling KMS Winches plus he's a blue star guy hear supporting RCC ,,,,Welcome to ,WERXRC , in Nampa, Idaho ,,just next door ,Check out his Indoor Rock Garden ,,Nice indoor coarse ,, Thank you ,,,Robert,,
www.werxrc.com
KMS is offline   Reply With Quote
Old 05-20-2014, 06:56 PM   #82
KMS
KMS's Avatar
Here's another new item for Heyok,,, It's the slow start winch controller with the resettable fuse ,,After testing ,, yep 2 of them ,,I highly recommend anyone with one of my winches to upgrade to this controller ,The best reason to me is it wont do the winch run away thingy when the radio is turned off ,,yahoo Heyok ,,The guys are going to like this product ,,Plus It has the resettable fuse ,,helps protect my winch and line ,,Yes The slow start is cool option as well,,, Robert ,,,
https://www.youtube.com/watch?v=kFWq7F4Ud3c
Old 06-01-2014, 05:33 PM   #83
I used both the k3 and ur free spool winch this weekend in a comp and again I will say I'm impressed with the balls these winches have and the free spool is flat out sick
kunas is offline   Reply With Quote
Old 06-12-2014, 06:16 AM   #84
Do you have a link to that winch controller? I can't find it in his threads.
Jeff@TireBalls is offline   Reply With Quote
Old 06-12-2014, 06:32 AM   #85
This is as close to a link as there is at the moment:
Winch controller with Soft Start. Should I develop one?
I haven't started producing this controller yet as I have been trying to keep up with my orders. Send me a PM if you want me to get one going for you. This will help encourage me to make it a regular item.
heyok is offline   Reply With Quote
Old 07-03-2014, 12:35 PM   #86
Deadbolt985 is offline   Reply With Quote
Old 07-11-2014, 06:40 AM   #87
Hey Robert, do you have a K2 and a k3 in stock?
Thanks, john.
stelerzman is offline   Reply With Quote
Old 07-11-2014, 08:12 AM   #88
KMS
KMS's Avatar
Thanks, john.
Blue Monkey rc should have K3 in ,,RPP hobby Should have both ,,Iam still healing up from a ladder accident ,,so moving very slowly ..But been supplying both hobby shops .... Thank you Robert
Old 08-13-2014, 09:50 AM   #89
I just bought a K3 freespool and was going to bring back the question of waterproofing. Anytips or tricks?
Also, is the freespool extended shaft stainless or regular steel? I would like to weld on an extension since the winch is up under my hood.
Szczerba is offline   Reply With Quote
Old 08-13-2014, 02:36 PM   #90
KMS
KMS's Avatar
Billj"s G6 Build
Bill has came up with a idea that seems to be working for water proofing the K3 servo winch . the shaft for the free spool push pin is stainless ,,might try cutting a 3mm thread on the end and using a link,
Thank you Robert ...
Old 09-18-2014, 02:42 PM   #91
Default oops
This is what happens when you lose signal to your RX.... Everything was fine thank goodness it plastic!
grunt95 is offline   Reply With Quote
Old 01-07-2015, 06:15 PM   #92
KMS
KMS's Avatar
As most of you know I have been using Tower Pro servo's for my servo winches ,It helps keep my cost down and makes it worth while to spend days no weeks in my shop building winches ,,I have been buying most my servos from one guy on ebay for the K3 /K2 180 servo winch ,,After my last order from him, it will be my last order from him ,,He has slipped me some TP clone type servo junk at 200.00 out of my pocket ,,Last time for him he can keep his 5 star rating ,,and sell his junk to someone else ,,
Now for the good news ,,My friend Patrick at Locked up Has helped me with a good contact for my servo's right from Tower Pro,, They have been up graded ,,new motor and gears ,,And there will be a new K3 added to the line up after testing ,,The servo's are costing me more each ,but I will be getting the same servo every order. I have had a few motor failures .Shouldn't be a issue any more ,,finger's crossed ,, If you have any problems with your winch and it needs repair send me a pm for my shipin address ,,so far just motors ,, There are K3 180 servo winches out there being used that are 4 years old ,,Not bad ,, Thank you for letting me rant and thank you to the Vendors that supply us here on RCC,,, Robert,,,.
Old 01-11-2015, 10:34 PM   #93
KMS
KMS's Avatar
Good news my first batch of servo's got here and the new servo's are great ,I have been testing one K3 & its a horse ,,,Great speed/power ,,Gonna make a great servo winch ,,Have 4 more to convert over and test ,,,Robert,,,
Old 01-25-2015, 09:32 PM   #94
KMS
KMS's Avatar
Helpful links to guys wanting a KMS servo winch now ,,If you want to get one now/soon,, Plus it supports the supporting Vendors/hobby shops that support us ,and who knows one of these guys might be one of you favorite hobby shops /From my experience they are all great guys and easy to deal with ,,The links I have here are for your help,,, Thank you,,, Robert
Winches, Blue Monkey RC
RPP Hobby | Radio Controlled Cars, Trucks, Boats, Helis, Planes, Plastic Models
CKRC Crawlers, RC Rock Crawlers
http://www.tcscrawlers.com/SearchRes...s+winch&Submit=
Old 01-28-2015, 02:12 AM   #95
Can I send you a couple servos to convert? Or can I buy the parts from you to try to convert my own?
BBCorvette18 is offline   Reply With Quote
Old 01-28-2015, 09:09 AM   #96
KMS
KMS's Avatar
Sorry ,, No conversion kits to much machining on servo case ,,,
Old 01-29-2015, 02:18 AM   #97
The servos I'd be interested in sending you a few of are the Turnigy tgy-5521MDHV servos. 338oz for about 30 bucks. They are aluminum case tho. If your interested in doing it let me know a price per servo to convert.
Old 02-02-2015, 08:39 PM   #98
RPP is sold out of the k3, do you know when they will be getting more? I figured if anyone knew, it would be you.
JOHNSON! is offline   Reply With Quote
Old 02-02-2015, 08:47 PM   #99
KMS
KMS's Avatar
Looks like I have been slacking ,, ,,There order is on the work bench ,,Should be two weeks ,,I will try to pick up the pace ,,Just I want them to be good quality ,,so it takes awhile ,,You need the best I can build,
Thank you Robert ,,,
Old 02-02-2015, 09:13 PM   #100
I had one sitting in my cart for about a week while i was adding items for a current build, and i went to go check out on Sunday and they were sold out I just placed an order with matt over at bluemonkey, he said he had three in stock. I will get one from him, just have to pay the shipping again.
KMS winch's all in one place - Similar Threads
KMS,,GI joe willy's KMS Large Scale Rigs 74 12-29-2016 02:00 PM
Is 3Racing winch's waterproof slashbasher Electronics 5 04-02-2010 11:37 AM
You may edit your posts
