06-16-2015, 12:42 PM | #1 |
| Toggle Switch Servo Positioner Toggle Switch Servo Positioner June 17, 2017: Made another version of this part. Now you can get a three position version. More info below. This part lets you position a servo just by flipping a toggle switch. Two trim pots lets you set exactly where the servo will park in both of the switch positions. No problem running a high voltage servo as this controller will take 10 volts. This part is now available for two or three servo positions. The three position version comes with a three position toggle switch. The center position puts the servo in the center of its rotation - therefore there is no pot for the center position. Update March 15, 2017 Now available with a speed control: I've had a few customers using this part for building their cosplay needs. Check out these two links: https://www.youtube.com/watch?v=xbfYJcIl2yw https://www.facebook.com/brian.w.wil...8815326673339/ Two position version is Part Number TGSP2 $30 Two position with speed control is Part Number TGSP2S $37 Three position version is Part Number TGSP3 $35 Last edited by heyok; 07-13-2017 at 11:13 AM. Reason: Photobucket support over, switching to imgur |
01-03-2016, 02:22 PM | #2 |
| Re: Toggle Switch Servo Positioner
Just realized that I didn't post up the video I made for this part. Here it is: https://www.youtube.com/watch?v=QxLUY6yRsxE |
06-08-2016, 10:51 AM | #3 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
Since I'm still on rtr tx do you have anything that I could use to set the endpoint on my steering servos? I just don't want to switch all my RCs over to one radio, since I've been getting my little bothers to come and play I need separate transmitters, plus they're kinda hard on my toys.
06-08-2016, 10:58 AM | #4 | |
| Re: Toggle Switch Servo Positioner Quote:
Toggle Switch Servo Positioner - Similar Threads | ||||
Position a servo with a toggle switch | heyok | Electronics | 17 | 06-18-2015 10:02 AM |
Servo Toggle Switch | heyok | Vendors Electronics | 19 | 03-18-2015 05:20 AM |
Servo positioner | heyok | Electronics | 0 | 10-17-2012 03:50 PM |
Can I get my Futaba 3PM 3rd channel to work a servo to toggle my light switch? | jedi | Newbie General | 2 | 08-10-2009 07:12 AM |
Toggle switch on a servo??? | Biscuit | Electronics | 1 | 04-11-2009 01:16 AM |
