08-30-2013, 08:48 AM | #1 |
| Two position channel, Park/Headlight controller
Two position channel, Park/Headlight controller Part number: 2PPKHL Use your two position channel to work your park and headlights. Both lights get receiver power (generally 6 volts) . Each push of the two position channel cycles the output as follows:
Park and head light controller from a two position channel - YouTube Part number: 2PPKHL $27 The picture also shows the dual power version such that the park light output gets receiver power (usually 6 volts) and the headlight output gets external power (if using 3S, about 12 volts). Part number: 2PPKHLEXT $31 Last edited by heyok; 07-22-2017 at 08:26 AM. Reason: Photobucket support over, switching to imgur |
05-05-2014, 03:32 AM | #2 |
Pebble Pounder Join Date: Apr 2013 Location: Central PA
| Re: Two position channel, Park/Headlight controller
Could this be used to toggle between my front/tail lights which will run on a 9 battery, and my 7.4v lightbar running off the receiver? My fly sky is hacked but I'd like to just be able to toggle between front/tail, front/tail and lightbar, and off.
05-05-2014, 06:25 AM | #3 |
| Re: Two position channel, Park/Headlight controller This would work for you if you could run both your lights from the same voltage. I could make you something custom to do what you are asking. Send me a PM if you are interested.
Two position channel, Park/Headlight controller - Similar Threads | ||||
Winch Controller for Radio with 2 Position Third Channel | heyok | Vendors Electronics | 121 | 05-19-2020 03:08 PM |
No Drift Winch Controller! (using 3 position transmitter channel) | heyok | Vendors Electronics | 239 | 12-12-2017 06:04 AM |
4 Wheel Steering Controller - controlled by a two position third channel | heyok | Vendors Electronics | 46 | 05-18-2016 08:26 PM |
MOA Dig Controller for Two Position Channel | heyok | Vendors Electronics | 26 | 03-24-2014 12:38 PM |
