11-08-2014, 06:24 AM | #1 |
| Variable Speed Winch Controller
This is an option that you can have added to your winch controller when you order a new controller. Variable speed requires a linear channel to run your winch. Or, if you use a three position channel, you can set the maximum speed of the winch by setting the end points. This option can be added to either of these winch controllers: 4 Amp Relay Output Winch Controller No Drift Winch Controller! (using 3 position transmitter channel) Watch a demo of the variable speed controller on a KMS winch here: https://www.youtube.com/watch?v=7Sd0...m-upload_owner This option will add $9 to the cost of the winch controller. Last edited by heyok; 03-02-2015 at 09:40 AM. Reason: Proof reading! |
11-08-2014, 06:31 AM | #2 |
| Re: Variable Speed Winch Controller
Very cool!
Tags |
variable speed, winch controller |
Variable Speed Winch Controller - Similar Threads | ||||
Working on new winch controller: Variable Speed | heyok | Electronics | 9 | 11-11-2014 06:34 AM |
winch controller 2 or 3 position TX switch with variable speed. New solution found | toy4crawlin | Electronics | 5 | 06-05-2011 10:25 AM |
Variable speed | PinileRC | Newbie General | 3 | 09-16-2010 09:48 PM |
