Receiver Power Distributor 2 Attachment(s) Ever need to send power from your receiver to more pieces of gear than you have available connections? Maybe this can help! Attachment 361108 Part No. RPD5 $5 Need a different size? Just ask. Send me a PM. Now available with a toggle switch: Attachment 361109 Part number: RPD5S Price $12 |
Re: Receiver Power Distributor Finally! Been wanting someone to do this for some time. Nicely done! |
Re: Receiver Power Distributor Quote:
Re: Receiver Power Distributor Nice......great idea.....ill be getting one for sure Sent from your moms house |
Re: Receiver Power Distributor Simple yet effective and budget friendly. I built myself a rx bypass in the same style as this, but using PCB for strength. |
Re: Receiver Power Distributor I foresee that quite a few could make use of this product. (I'm currently not one of them.) My main worry about using the Rx for power distribution in the first place is that the leads on the Rx board are so thin that there's a potential for power loss and heat development if lots of current is required. The solution is to bypass the Rx and have the power source (ESC or separate BEC) attached to a separate distributor like this one. If the ESC's internal BEC is used that also requires a signal cable though. Here's my idea (which is now public and free for anybody to use): https://0pqbqg-dm2305.files.1drv.com...tor.jpg?psid=1 22AWG for the wires is preferred for low resistance.
Re: Receiver Power Distributor will this work with a 3s lipo? instead of through the receiver |
Send me a PM and we will figure something out. |
Re: Receiver Power Distributor can you do this with deans? |
Re: Receiver Power Distributor Do you want a Deans connection for the power in and leave the outputs the same? Sure. Did you mean something else? |
Re: Receiver Power Distributor I don't really know what I want but I need something to easily plug and unplug my lights to. I have my battery powering them directly and need something that can act as a plug for individual lights. |
Re: Receiver Power Distributor Do your lights have a connector on them already? |
Re: Receiver Power Distributor Would it work for you if I replaced the servo plug (this part) http://www.the-border.com/images/D/servo%20plug.jpg With a deans or double deans style plug? (couldn't find a picture of it by itself, but the double deans is shown in this picture) http://i181.photobucket.com/albums/x...ps874afa78.jpg |
Re: Receiver Power Distributor that would work nicely! how do I attach those other connections though? I usually solder stuff up, but I don't know how those receiver plugs work I sent you a PM |
Simple update to Receiver Power Distributer Added a toggle switch to the Receiver Power Distributer so now you can have an easy way to turn your lights on and off right on your rig! Attachment 361109 Part number: RPDS Price $12 |
