Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Electronics
Thread: Wireless Winch Controller
Old 06-03-2015, 01:29 PM   #1
Thumbs up Wireless Winch Controller
This lets you run a winch without using up a channel on your transmitter!
Save that channel for some other accessory like a lighting controller
Simply plug the double Deans style connector between your battery and ESC.
Now when you push a button on the key fob remote control, full battery
voltage gets switched via the same type of circuit used in the business
end of the 4 amp relay output winch controller link
This controller needs to from 6 to 12 volts to operate (a 2S or 3S lipo pack will work).
Part Number WWC
$60 plus shipping.
Also available with Soft Start for $10 more. This causes the winch power to ramp up over about 1/2 a second in order to be more gentle on the winch gears and line.
Part Number WWCSS
$70 plus shipping.
Prefer to have a JST connector on the output?
Order Part Number WWCJST
$62 plus shipping
Need the case you see in the pictures? Add $4 (it makes the shipping price jump up, so that is how I cover the cost).
Send me a PM if you would like to place an order.
heyok is offline   Reply With Quote
Old 06-03-2015, 02:14 PM   #2
Default Re: Wireless Winch Controller
This part was discussed here:
Working on a new Wireless Winch Controller
Old 07-02-2015, 11:48 PM   #3
Curious if these are offered with different frequencies? To be able to use more than one near one another.
jonboyauto is offline   Reply With Quote
Old 07-03-2015, 06:18 AM   #4
They all use the same frequency band but they all have different security coding, so yes, you can use more than one near one another.
Old 07-05-2015, 05:56 PM   #5
cgw
Can this be ordered without the remote if I already have that model remote from a controller that burned up?
cgw is offline   Reply With Quote
Old 07-05-2015, 08:13 PM   #6
Send me a PM. Maybe we can work something out.
Old 08-25-2015, 01:32 PM   #7
What are the voltage limits for this? safe to run on a 3s lipo?
J.Peart is offline   Reply With Quote
Old 08-25-2015, 01:42 PM   #8
Yes, 3S lipo is good. Don't take the input voltage much over 12.
Old 08-25-2015, 01:48 PM   #9
Cool, thanks. Looks like ill be ordering one of these.
Old 08-25-2015, 01:49 PM   #10
That's great!
Send me a PM and I will take care of it for you.
Old 12-07-2015, 06:51 PM   #11
i know someone asked if this would work with a different remote, but will your controller work with the older RC4WD remote unit? not the Warn-branded version?
Sent from my LG-D850 using Tapatalk
k_bojar is offline   Reply With Quote
Old 12-07-2015, 07:23 PM   #12
The remotes are locked to the receiver, so no. Sorry.
Old 12-07-2015, 07:46 PM   #13
bummer. oh well... guess I need to scrape some change together lol
Old 12-14-2015, 12:02 PM   #14
Exclamation Wireless Winch Controller for 3S
Like this part but want it for less money?
I have a few of these left. They work at 3S (12 volts). Lower voltage won't operate the relays.
Read about them here:
Wireless Winch Controller for 3S ->Lower price!
You may edit your posts
