Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Vendors Electronics
Thread: Ckrc Wiggle Servos
Old 06-14-2007, 05:36 PM   #1
KING BLING's Avatar
Default Ckrc Wiggle Servos
THE WIGGLE SERVO. THESE SERVOS HAVE THE TORQUE YOU NEED FOR 2.2'S OR SUPERS.
I HAVE BEEN SELLING THESE AT THE SHOP FOR 3 MONTHS NOW AND HAVE YET TO SEE ONE BREAK A SET OF GEARS OR GO UP IN SMOKE. THESE SERVOS HAVE FULL METAL GEARS, DUAL BALL BEARINGS, AND 196 OZ/IN TORQUE AT 6V.
EVERY SERVO THAT LEAVES THE SHOP WILL BE TESTED TO MAKE SHURE IT WORKS SMOOTHLY, SO DONT BE WORRIED ABOUT GETTING BAD SERVOS.
THE PRICE IS $34.00 SHIPPED ANYWHERE IN THE LOWER 48 STATES. OUTSIDE THE US, PLEASE PM ME FOR A SHIPPING QUOTE.
PAYPAL TO CKRAWLER@SBCGLOBAL.NET
SPECS:
Dimensions: 1.6 x .78 x .61 inches 40.5 x 20 x 41mm
Speed: .17sec/60deg @ 4.8v, .15sec/60deg @ 6v
Torque: 182oz/in @ 4.8v 196 oz/in @ 6v
Weight: 46Grams 1.73 Ounces
Bearing: Dual Ball
Gears: Metal
HITEC TYPE PLUG
KING BLING is offline   Reply With Quote
Old 06-14-2007, 05:45 PM   #2
What kind of servo arms does it use?
FinishLineRC is offline   Reply With Quote
Old 06-14-2007, 05:50 PM   #3
KING BLING's Avatar
THE HORN IS LARGER THAN A HITEC ONE. WE HAVE BEEN USING THE ONES THAT COME WITH THE SERVO OR THE ALUMINUM DURATRAX ONES.
http://www2.towerhobbies.com/cgi-bin...?&I=LXHWR1&P=7
Old 06-22-2007, 10:07 AM   #4
KING BLING's Avatar
http://www2.towerhobbies.com/cgi-bin...?&I=LXFVK9&P=7
WE HAVE FOUND THESE TO FIT WELL ALSO.
Old 06-24-2007, 07:07 PM   #5
Can you buy replacement gear sets? What brand are they?
mauromj is offline   Reply With Quote
Old 06-24-2007, 10:20 PM   #6
Rockpiledriver's Avatar
I believe that would be an Integy Servo. Just put one on my rig the other day. It works fine so far and has higher torque and is cheaper than an HS-645. A little on the noisy side.
Rockpiledriver is offline   Reply With Quote
Old 06-24-2007, 10:43 PM   #7
Looks like a dead ringer for the TowerPro 945/995...especially with the Futaba horns working on it
DeaDShorT is offline   Reply With Quote
Old 06-24-2007, 11:33 PM   #8
It's not a Tower Pro I can assure you that... I'd guess Integy or Blue-Bird makes them.
Old 06-25-2007, 12:45 AM   #9
have you tried these in a nitro mt ?
twisted is offline   Reply With Quote
You may edit your posts
