Go Back   RCCrawler Forums > Vendors > Vendors Market
Thread: Official VF/DNA/BWD Customer Service/Feedback Thread
Old 09-07-2008, 02:26 PM   #61
Ultimate RC Decals
BOWTIE's Avatar
:-( condolences out to you and family.
BOWTIE is offline   Reply With Quote
Old 09-07-2008, 05:42 PM   #62
Moderator Rule Breaker
eric113's Avatar
X 2 :-(
Don, If yall need help, give me ring!!
eric113 is offline   Reply With Quote
Old 09-07-2008, 06:44 PM   #63
x2 if you need anything let me know
buster22 is offline   Reply With Quote
Old 09-08-2008, 03:27 PM   #64
DNA R/C will be releasing a much impoved shift fork rod to replace the once threaded item. The new fork and rod assembly will be press fit to eliminate ANY issues that may have occured in the past. These will be released on ALL new DNA Dig units. Also they will be available for spares/replacement. If you have purchased a dig in the past 10 day's please e-mail customerservice@dna-rc.com and we will replace your fork and rod. This will require you to return the old setup.
210solomon007 is offline   Reply With Quote
Old 09-11-2008, 06:58 AM   #65
Originally Posted by ZORLAC View Post
just wondering what was the ETA looking like on the DmG's order ???
thanks guys
the DmG
Originally Posted by 210solomon007 View Post
got the small qty cut. Working on the 100qty.. Ships monday with great quality... Thanks DMG another Great Vendor!!!
still waiting & wondering ???
my condolences to don & the family
The DmG
the DMG is offline   Reply With Quote
Old 09-11-2008, 07:16 AM   #66
The DmG
Pm sent.... Thanks....
Old 09-11-2008, 10:41 AM   #67
just got in my new dig and slingshot from jph, dig went together smooth with no issues, still need to hook up a servo, but hand operation is smooth, just like the last one I bought. Slingshot looks great, but I have one bent link that appears to be shorter than it should be. it is a lower link, it also has more of a bend to it.
Lushtrucker is offline   Reply With Quote
Old 09-11-2008, 01:43 PM   #68
Give me your address and I will shoot you out another.
Old 09-11-2008, 06:38 PM   #69
pm sent, thanks for the quick response!
Old 09-12-2008, 07:54 PM   #70
Got it... Get you taken care of...
Old 09-13-2008, 09:46 PM   #71
Default dig unit problem
The 1/8th inch shaft for the shift fork was boogered up on the ends and the threads were way more tapered than pipe threads and would not screw into the shift fork rather the whole shaft would slide through it. I also have another problem but would prefer to talk to you over the phone at 205-233-2015 or205-233-2335. I received my unit Wednesday and have been leaving voice mails ever since. I understand you are very busy but this is the last thing i am waiting on.
Vortex1 is offline   Reply With Quote
Old 09-14-2008, 11:54 AM   #72
Replied to. Call you in the morning to get you taken care of.
Old 09-15-2008, 09:23 AM   #73
Lower link on the way. Also put in some stickers
Old 09-15-2008, 09:24 AM   #74
Called and left my cell with your Gfriend..
Old 09-15-2008, 08:54 PM   #75
I bought a VF unit in April 08. Is this the first upgrade since then ? Im have binding issues going from dig into 4X4.
210Soloman007 ........... YGM
Creepy is offline   Reply With Quote
Old 09-16-2008, 08:34 AM   #76
This is not a "upgrade" for the fork. Just the rod. This eliminates the threading issuses that have come up in the most recent digs. have you adjusted anything since your installation?
Old 09-16-2008, 06:47 PM   #77
ghetto fabulous newbie
Don, Please Clear your PM box so I can PM yea, or just shoot me a PM.
Thanks
yotachump is offline   Reply With Quote
Old 09-16-2008, 08:19 PM   #78
Just played with endpoints. It never has worked without binding on the way into or out of lock.
Did you read the e-mail I sent you last night, it may help clarify the problem. I really need to get it fixed, and I dont mind sending it in if need be. Please let me know, thanks
Old 09-16-2008, 08:23 PM   #79
I got my DNA dig in the truck today and it works perfect. But I would like some clarifaction on the part being fixed. My rod screwed in to the shift fork does that mean its the old one.
Thekingcrawler is offline   Reply With Quote
Old 09-16-2008, 08:37 PM   #80
thanks for hooking me up DNA
my dig works alot better now-
should I use 2 set screws to hold the driveshaft to outputs?--have MIPS/thundertech using 2 set screws, but after about 10min. of bashing and binding(torture testing) the driveshafts "come loose", screws are still tight--they are actually digging/rounding the outputs(happens on both front and rear shafts-eventually).
What are my options?
make bigger flats
make bigger flats with a small hole for set screws
or
drill hole all the way through and use a long set screw?(think this will break the output?)
barbaricboye is offline   Reply With Quote
You may edit your posts
