01-19-2009, 12:45 PM | #81 |
RCC Addict Join Date: Jul 2008 Location: Sin City
01-25-2009, 04:01 AM | #82 |
Quarry Creeper Join Date: Dec 2006 Location: Finland
That's SICK one! Any more teaser shots?
01-27-2009, 07:15 PM | #83 |
RCC Addict Join Date: Apr 2008 Location: In The Machine, "Turn the light back ON"
They are shipping !!!!!!!!!!!!!!!!!
01-27-2009, 08:37 PM | #84 |
Quarry Creeper Join Date: Mar 2008 Location: Raleigh, NC
They aren't on your website ! How do we order ? |
01-27-2009, 09:16 PM | #85 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
Im with toytech... I want mine NOW Last edited by DiEzel; 01-27-2009 at 09:19 PM. |
01-28-2009, 05:20 AM | #86 |
This first release is going to dealers/Distributors( Hobby Shops) so I will get them to post so you guys know where to get them.
02-02-2009, 08:54 AM | #87 | |
Rock Crawler Join Date: Dec 2005 Location: Connellsville PA."fayettenam" lol
| mantis Quote:
02-07-2009, 02:00 AM | #88 |
Quarry Creeper Join Date: Oct 2008 Location: Folsom
Let us All know by PM when they are available to the public and not the local shops.. since no one around me has it... Already asked.. they looked at me like I was crazy.. DNA what??? Go figure Thanks J |
02-07-2009, 10:01 AM | #89 |
Pebble Pounder Join Date: Dec 2004 Location: NYC
Stick King you lucky!!! They don't list them available on their site. Waiting for a reply. Hook us up Anthony, please!!!
02-13-2009, 09:06 AM | #90 |
Rock Stacker Join Date: Feb 2007 Location: Finland
02-17-2009, 12:47 AM | #91 |
| Now that i have it i dont know if im going to run it, damn so many chassis, so few MoA sets. |
02-22-2009, 08:28 PM | #92 |
Quarry Creeper Join Date: Oct 2008 Location: A little town called Dallas
This chassis makes me want to build a MOA on Bergs soooooooooo bad
02-25-2009, 06:46 PM | #93 |
Quarry Creeper Join Date: Oct 2008 Location: Jamestown
I just got my chassis in and I have different links than what i see in the pics above. I got two long ones for the rear and 4 of the same sized ones for the front i take it? The 4 "smaller" ones also were tapped 4 3mm instead of the included 4 mm screws. I got no spacer for the chassis also. I was able to get the rear hooked up and the chassis seems to have no flex at all in the rear so i was curious if there is a correct way it should be put together? I sent ya an email Sol Last edited by swisherteets; 02-25-2009 at 06:52 PM. |
02-25-2009, 07:29 PM | #94 | |
02-25-2009, 07:35 PM | #95 |
awsome thanks Sol |
03-02-2009, 09:08 PM | #96 |
Rock Stacker Join Date: May 2008 Location: Miller Park
| I received the same thing in my kit. Are there supposed to be 4 equal length links with no spacer up top? Thanks. |
03-02-2009, 09:34 PM | #97 |
Keep Crawling in Crawling Join Date: Jan 2009 Location: Commerce City
I also received only four shorts and two longs in the kit I recieved. I started putting it together and also felt like the rear had no flex at all. I got frusterated with the set up and sold it. Hopefully someone can make it work. I was disappointed but it is a completely different direction than I am use to.
03-03-2009, 09:50 PM | #98 |
Rock Crawler Join Date: Jul 2006 Location: Olympia
Could one of you please post a picture of what you got. Also please post a picture of the progress you finished in the build. Going off memory here.....Uppers should be 58mm Lowers should be 78mm. Seems the rears should be around 114mm. Again off memory, battery died in my measure. Keep in mind until you have the weight of axle's, motors, wheels, tires, etc. you will not really be able to really flex it. You will want a spacer between upper shock mount, also would use one between were the rear links mount at chassis. |
03-03-2009, 10:53 PM | #99 |
RCC Addict Join Date: Apr 2008 Location: Singapore
Here's a Mantis on a Bully trying-out with some spacers.
03-03-2009, 11:27 PM | #100 |
My progress has been slow as this is my first build with the berg axles. After I watched the teaser video with the Mantis I could see this is a hot setup for the axles. Using parts off my Axial to do the mock-up. Jato Rod ends, had them on the shelf. Jato's measure around 26mm from the center of the hole to the end. With the scrap rod that was cut off the rears I was able to piece links together for front link mock up. I have one 6mm spacer each side on the lower front chassis and 2 6mm spacers on top for the shocks. As it sits now, I have very little axle steer or roll, and nothing is touching through the range of articulation (motor or gearbox housing). The shocks have 2 pen springs inside that limit the shock travel to 34mm total stroke. You are correct, when I get the rig loaded up I will be able to determine total flex. WB = 12 3/16" Chassis height little over 2 5/16" @ the lowest point. Add 52mm for center to center length. Rear links, 60mm Front uppers, 22.5mm Front lowers, 21mm Has anyone tried a clocked front axle yet? Last edited by slick; 03-03-2009 at 11:32 PM. |
