08-26-2009, 03:17 PM | #1 |
Rock Crawler Join Date: May 2006 Location: Georgia
| Axial SCX10 TR (Trail Ready) In stock and shipping!! http://www.tcscrawlers.com/Pre-Order...2-p-17878.html SCX10 TR (Trail Ready) Complete ready to run out of the box. 4WD. 27T Electric Motor: Tear up the terrain in-door or out-doors. Easy Operation: No Tuning, No Fuel, No Loud Exhaust Noise. Just Plug'n'go! 20T pinion paired with an 87T spur gear gives you quick acceleration while still allowing for a smooth low end speed range. True Beadlocks: No Messy Glue! Hi-quality Composite Plastic and Metals. 6 LED's: 4 white LED’s for the front and 2 red LED’s for the rear. Electronic Speed Controller (ESC): forward and reverse speed controller. Hi-Torque metal gear servo helps hold your line when rock crawling. Solid Rear Axle lockouts improve ground clearance and offer a more realistic appearance. Slipper Clutch: Reduces gear wobble for a more efficient drivetrain. Allows a motor to work more efficiently and greatly enhances the durability of the drivetrain. Steel chassis rails with a molded composite plastic cross members provide a solid and rigid chassis. Ultra compact and lightweight transmission. Full Ball bearings. Overall gear ratio range from 15:1 to 74:1. Transmission: 2.6:1; center mounted. Tires: Pro-Line 1.9 Flatirons tires. Wheels: Axial 1.9 8 Hole Beadlocks (Satin Chrome). Suspension: 3 Link. Drive Shafts: Universal front and rear Chassis Dimensions a. Wheelbase: 290mm (11.4”) b. Width: 227mm (9”) c. Height: 150mm (5.9”) d. Weight: 2086g (4.6 lbs) Ground Clearance: 68mm (2.7”) Body Dimensions a. Length: 425mm (16.7”) b. Width without fender flares: 180mm (7.0”) c. Width with fender flares: 226mm (8.9”) d. Height: 145mm (5.7”) Electronics a. Radio: 2 Channel b. Servos: 1 Hi-Torque metal gear (Standard Size) c. Forward/Reverse ESC d. Motor: 27T 540/550 Size Required Items a. (1) 7.2v Stick Pack Battery b. 8 AA size Batteries http://www.tcscrawlers.com/Pre-Order...2-p-17878.html http://www.tcscrawlers.com/Pre-Order...2-p-17878.html Last edited by TLTRyan; 10-03-2009 at 01:43 PM. Reason: update |
08-26-2009, 03:19 PM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Conowingo, Maryland
wish i could get one but got a baby on the way |
08-26-2009, 03:56 PM | #3 |
Pebble Pounder Join Date: Jul 2008 Location: bedrock
08-26-2009, 10:05 PM | #4 |
Pebble Pounder Join Date: Apr 2009 Location: Prescott Valley
that thing is great, the body beat the heck out of the scx10 origoinal body... time to start saving.
08-28-2009, 04:45 PM | #5 |
RCC Addict Join Date: Jun 2008 Location: Fresno
any word on when a conversion kit for the original scx10 is comin out?
08-28-2009, 08:40 PM | #6 | ||
The body/cage does have a separate part #AX4010 The bumpers and rock sliders are not included. Quote:
I also own an SCX-10, but for the money this thing looks very nice. | ||
09-26-2009, 12:26 AM | #7 |
| I just received information that the Trail Ready trucks will be here soon. We are running a promotion on them. Get $25 off your Axial Trail Ready! Just add the Axial Trail Ready to your shopping cart to get $25 off instantly! Offer ends October 1st. Follow the Link to Pre-Order. http://www.tcscrawlers.com/Pre-Order...2-p-17878.html Last edited by TLTRyan; 09-29-2009 at 10:15 AM. |
09-26-2009, 09:39 PM | #8 |
RCC Addict Join Date: Jul 2006 Location: barstow
what about somebody that had already pre-ordered it from you a month ago ?
09-27-2009, 05:05 AM | #9 | |
09-27-2009, 02:00 PM | #10 | |
10-03-2009, 01:41 PM | #11 |
All Pre-orders shipped last week. We still have a few in stock They wont last long. http://www.tcscrawlers.com/Pre-Order...2-p-17878.html |
10-04-2009, 07:02 PM | #12 |
Rock Stacker Join Date: Sep 2009 Location: Austin
Just ordered mine Any advice on cheap ways to make it a bit more realistic? I want to do like a Blazer or 80s bronco body, with bumpers and such, but I have no idea where to start... |
10-04-2009, 07:17 PM | #13 | |
I would check out some of the build threads in the scale section. You will get lots of ideas. Pro-Line makes some bumpers if you don't like the look of the stock ones. http://www.tcscrawlers.com/Proline-Western-Bumpers-6052-00-p-17222.html Have you seen the Blazer CGR? I have always liked the look of it. http://www.tcscrawlers.com/On-Sale-5...0-p-17312.html | |
10-04-2009, 10:57 PM | #14 | |
How would this body https://www.tcscrawlers.com/Proline-...0-p-17223.html work? I am not really sure how to look at it and know if it will look right on the SCX10's wheelbase and width and such. And would these https://www.tcscrawlers.com/Proline-...0-p-17222.html work well with this body? Like how much fabrication am I looking at to get it all fitting up well? I can handle some | |
10-05-2009, 07:02 PM | #15 |
The F-100 is a little narrower. Wheelbase should be close, its not hard to lengthen or shorten your links if needed. Im sure someone in the SCX-10 section has installed the F-100 body on the stock chassis. In may be worth a look. |
10-06-2009, 12:47 PM | #16 |
ahhhhhhhhhh the wait is killing me!!!! *shakes fist at mail man* Yeah its only been 1 day and I am already watching the mailbox lol I am fiending for this thing. I litterally have my other desk cleared off with a freshly charged stick pack, 8 fresh AA batteries (didnt know if it took 4 or 8 for the xmitter) a pair of scissors and a razor blade, so that I can bring it right in, open it up, slap batteries in it and go run over things before the mailman has even reached the end of the block |
