10-01-2008, 07:10 PM
#1 |
| RCC Addict
| CKRC Crawlers, Tamiya Tamiya 1/10 Mercedes-Benz Unimog 406 Kit **In Stock** Tamiya Tamiya 1/10 Mercedes-Benz Unimog 406 Kit In Stock at only $329.99 You can get then here: UNIMOG- The Mercedes-Benz Unimog's body is made from lightweight polycarbonate material.
- CR-01 chassis features a heavy-duty ladder frame with strong lightweight pressed aluminum channels and cross channels.
- 4 link coil suspension provides the flexibility needed to conquer difficult rocky terrain.
- Center gearbox features planetary gears with a compact design enabling the battery to be mounted lower for a better center of gravity.
- Newly designed 3-piece beadlock wheels mounted with massive 125mm diameter and 6mm wide rock crawler tires are ready for any terrain.
- Powered by a 540 motor.
- Can be fitted with Yellow (Front) and Red (Rear) TLU-01 LED Lights (ITEM 53909)
- The Unimog is compatible with a wide range of Option Parts
