Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Paint and Body
Thread: Bomber Fabrication Aluminum Panel Upgrades from CFM
Old 02-11-2017, 08:20 AM   #21
Default Re: Bomber Fabrication Aluminum Panel Upgrades from CFM
Been looking for the sway bar disconnects for a year now, always OS....
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 02-11-2017, 09:28 PM   #22
What type of aluminum do you use, and how thick? Ordered up some inner fenders and extended sides tonight. Debating between you or AMF for roof and hood. AMF uses "Aircraft grade" aluminum that is .040 thick. They are more expensive however. I believe barndog uses .032. Not sure if the extra thickness on AMF a huge deal, and not sure what type of aluminum is best for panels. If you can make a case for your hood and panels I think I would prefer to support your product. I just want solid panels on the areas that take more of a beating.
Also, do you have any powder coating options? If not, do you have any recommendations or tips for painting these panels, or would vinyl coating be better?
theTman is offline   Reply With Quote
Old 02-11-2017, 09:55 PM   #23
Metal shaper
.032 3003
Highly doubt anyone is using 6061 for panels. Its way more expensive and unnecessary.
Also what they don't realize when using thicker material is the lack of threads you now have. I know you're gonna say .008" ain't gonna matter but it does since we've already increased thickness over stock panels by using .032".
We are the originators and have the leading designs in panels. No one else does what we do, and that's hand form. You'll notice other panels are formed on a break giving them hard bends when there should be a radius bend to match the cage. We match whatever the cage does to give the best fit and look available.
No aluminum panel is gonna last forever, but at our price point, originality, and quality; you won't find a better panel on the market.
For coating, we don't offer a service since we have to job that out and leads to long wait periods out of our control.
For paint:
Scuff with scotch brite pad
Wash in warm soapy water and rinse clean
Avoid touching with bare fingers
We have good luck with Krylon brand paint
We are also working with Freqeskinz and will have all his wrap designs for our panel lines too. Just another advantage the other guys don't have.
CarterFab is offline   Reply With Quote
Old 02-11-2017, 09:56 PM   #24
Metal shaper
Hang up and Drive
They are discontinued for the time being.
Old 02-12-2017, 06:39 AM   #25
Bummer !
Hang up and Drive
Old 02-12-2017, 08:32 AM   #26
.032 3003
For paint:
You've won me over
Is it cheaper shipping wise to get everything at once. If so, I would like to throw a roof into my order if it isn't too late. I ordered late last night. Any idea when hoods will be back in stock? I want one of those too.
Edit: It looks like it cost the same to ship the roof, sides, and inner fenders as it would the roof alone. I sent a message on your site's contact form to add the roof to my order.
Old 02-12-2017, 12:31 PM   #27
Metal shaper
You've won me over
Just updated inventory. Place a new order for the extra parts and I'll refund shipping on that order and combine for you.
Old 11-07-2017, 08:51 AM   #28
Do you make a panel for the rear end to go where the spare tire mount is? (I took mine off.)
Sent from my Nexus 5 using Tapatalk
MasteroFlego is offline   Reply With Quote
Old 09-26-2018, 12:03 PM   #29
The shopping cart feature on your mobile web site doesn’t seem to work. I’m looking to pick up a set of the extended side panels. Can we order here or over the phone?
IV WHLN is offline   Reply With Quote
Bomber Fabrication Aluminum Panel Upgrades from CFM - Similar Threads
CFM: Yeti Upgrades Lisiting CarterFab Vendors Paint and Body 30 07-03-2016 10:22 PM
cfm aluminum body Austin92 Paint and Body 4 11-06-2013 12:17 PM
You may edit your posts
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
