Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: *******Wheel Works 2110 bead locks*********
Old 08-10-2009, 05:34 AM   #41
Got mine in this weekend and dang, these things look AMAZING!!! They came in right at 7.2oz with Rovers and stock foam. They are perfect!! I just can't say enough about how good the quality of work is that went into these!!! Your the man Steve...
-Jason
KrawlOff-Road.com is offline   Reply With Quote
Old 09-19-2009, 05:34 AM   #42
So if you have a LosiCC these wheels will bolt right up to the rear and narrow your track about 1/4" over the front. Great for squeezing through gates and making even tighter dig turns And they are light!
They will also do the same thing on the front of the LCC but you have to bevel off the corner of the inner locking ring so it won't rub on the knuckle any. It almost fits without modification, so you could probably put a small shim behind the wheel and make it work. Hey... I think I'll try that.
Harvo is offline   Reply With Quote
Old 09-19-2009, 10:04 AM   #43
TEAM MODERATOR
Reflection's Avatar
You've got the Berg offset That's the reason you have to trim the rings. The Axial offset works fine.
Reflection is offline   Reply With Quote
Old 09-19-2009, 01:32 PM   #44
I think the Axial offset in this wheel is a very good choice for the LCC. Might have to pick up some
You may edit your posts
