07-06-2010, 02:02 PM | #1 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
| GCM Cast Mercedes G-Series 1.9 Wheels
Introducing GCM Cast Metal wheel sets. This wheel was designed and cast in Germany and showcased here in this amazing G wagon Build. These wheels come ready to use as a cast wheel, with machined features, but can be detailed at nausium for extra realism. The user can decide on colors and detailing according to each use and project. Here's the Nickel-Silver wheel on the left. This wheel is incredibly strong and won't crack or bend. Easily polished and painted/stripped how ever you wish. Direct fit for the required GCM Rotors for a 4mm hex face spacing. The Aluminum cast wheel is on the right. Amazing low weight, so light you think it's made of foil. Very strong in it's cast form and won't chip or crack easily. Easily painted/stripped for custom touches or polished. Rotors machined completely from Billet hardened aluminum and include all mounting screws and a new lock nut for the axle. Finished in Anodize and re-machined for the true-rotor look. Mounts to just about any 12mm hex with a flat face. Some of the metal hexes with real sharp hex points may require points to be slightly rounded to fit into the rotor. The hex socket on the rotor does not allow for perfect sharp hex corners. Web Page and shopping page are available here at this link. We do have some stock currently ready to go. We will also accept pre-orders for following production runs, which we intend to do on a regular basis. Please send a note if you have any questions. GCM Contact Page Link Last edited by Generis; 08-09-2010 at 02:28 PM. |
07-06-2010, 02:08 PM | #2 |
More pictures of the finished units: |
07-07-2010, 10:03 PM | #3 |
Nickel-Silver cast wheel with Rock Creeper 1.9 tire Aluminum Cast wheel with Rock Creeper 1.9 tire 13 inch wheelbase Ford truck |
08-09-2010, 02:33 PM | #4 |
Aluminum wheels now in stock. The Nickel-Silver wheels are coming in stock again in another couple of weeks. Shown below on a 10 inch wheelbase Jeep, GCM 4TEN leaf spring frame, and RC4WD RockCreeper 1.9 tires. |
08-13-2010, 10:52 AM | #5 |
Nickel-Silver wheels back in stock now.
