05-21-2011, 08:23 PM | #1 |
Quarry Creeper Join Date: Jun 2009 Location: Canon City
| 2.8" bead lock wheel for Traxxas or ???
Thought some of you might have an application for these. They were designed for a Traxxas Jato which is a 2wd rc so the back wheels have your basic 12mm hexes and the front wheels use bearings. I can definitely sell 4 wheels with hexes. As always be sure to contact Motoworx for your custom needs Specs: overall diameter 3.2" Tire diameter is 2.8" Width is 1.8" before bead locks See more here. http://www.motoworxracing.com/traxxasrc.htm Last edited by motoworx; 07-03-2011 at 05:15 PM. |
06-01-2011, 05:21 AM | #2 |
Quarry Creeper Join Date: Nov 2009 Location: Kaplan
Would these wheels fit a traxxas stampede 4X4? |
06-01-2011, 06:23 AM | #3 |
| stampede |
06-01-2011, 07:20 AM | #4 |
If you could find out for sure I might be interested in a set.I know the require alot of room behind the wheel due to 4 wheel drive.
06-01-2011, 11:30 AM | #5 | |
Thanks Jake | |
06-01-2011, 11:53 AM | #6 |
I have the stock wheels on my truck.I could test the fitment if thats something you want to do.I like the look and beadlock style wheel so if they would work it would be pretty awesome.
06-01-2011, 05:08 PM | #7 | |
As long as they are a 12mm hex they should fit. If you think your linkage and steering knuckles are different than a Jato than we should check. The diameter of the inner wheel well on this wheel is no less than 2.5". I am sure hex works because traxxas list that there 2.8 wheel works for Jato, Rustler, and Stampede. http://traxxas.com/products/parts/ti...28ChromeWheels Initial test have come back and report that the bead holds outstanding. Jake | |
06-01-2011, 07:08 PM | #8 |
Yea the stampede 4x4 has much larger axle carriers.I could send you some photos of the clearence with the stock wheels once I get home from offshore.
07-03-2011, 05:18 PM | #9 |
| updated design |
