Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: DLUX 2.2 AND 1.9 wheels
Old 01-04-2012, 05:25 PM   #21
Default Re: DLUX 2.2 AND 1.9 wheels
Man... i just took my tires off the rims yesterday... I would help if i could
Hittman is offline   Reply With Quote
Old 01-05-2012, 02:22 PM   #22
Got mine today...Can't wait to get home. Thank Erik
erikblank is offline   Reply With Quote
Old 01-05-2012, 04:02 PM   #23
Wanna get? Gotta want.
Erik D_lux's Avatar
Awesome! I just updated the instructions for the wheels, looks like its just in time.
Thanks and let us know how you like them.
Erik D_lux is offline   Reply With Quote
Old 01-06-2012, 10:42 AM   #24
Please confirm. Does the weight system work also with 1.9 wheels?
lenage is offline   Reply With Quote
Old 01-06-2012, 12:43 PM   #25
Erik D_lux's Avatar
No. When I get some time I will look at making something but I am guessing there just isnt enough room for weights.
Old 01-06-2012, 01:05 PM   #26
Originally Posted by Erik D_lux View Post
Track widths according to SLW hub size and car: Values not guaranteed to be accurate.
Berg
All taken with Sedonas, outside tire to outside tire
850 hub = 11.125
725 hub = 10.875
600 hub = 10.625
475 hub = 10.375
350 hub = 10.125
225 hub = 9.875
XR
850 hub = 11.5
725 hub = 11.250
600 hub = 11
475 hub = 10.750
350 hub = 10.5
225 hub = 10.250
AX10 front
May want to consider my 1/4" hub spacers for more options. Add .520 to the below values if you add the 1/4 hub spacer.
All taken with Hater aid, outside tire to outside tire
850 hub = 10.750
725 hub = 10.5
600 hub = 10.250
475 hub = 10.00
350 hub = 9.750
225 hub = 9.500
LCC
850 hub = 10.375
725 hub = 10.125
600 hub = 9.875
475 hub = 9.625
350 hub = 9.375
225 hub = 9.125
MRC front axle
All taken with Rovers, outside tire to outside tire
850 hub = 8
725 hub = 7.750
600 hub = 7.5
475 hub = 7.25
350 hub = 7
225 hub = 6.750
All other cars, I need values if anybody wants to share....
Are these widths for front or rear axle?
ManxCrawler is offline   Reply With Quote
Old 01-06-2012, 01:09 PM   #27
Erik D_lux's Avatar
Looks like I missed the labeling of the XR. Its a front measurement. All the rest should be correct.
Old 01-06-2012, 01:20 PM   #28
Yeah mines an XR, thanks Erik
Old 01-07-2012, 10:35 AM   #29
These are the lightest! 3.85 oz. for wheels, 4" cut & shut pin tires, memory foam and all the hardware. I have the polycarb face. Right now I'm running them in the rear only.
Old 01-07-2012, 11:53 AM   #30
This is what I came up with for the 1.9 wheels
I picked up some collars from hi strength nut and bolt. They are 3/4". I needed to open up the Id a bit so out came the uni bit.It steps cuts obviosly but that was a plus since these are slipping over the SLW hubs and they are tapered.
Installed over SLW,just a press fit and then use the supplied set screw to lock them down.The set screw will fit right inbetween the ribs on the SLW hubs.
Installed on wheels
I also picked up some 7/8 split collars to use.They are bit big in the od and need to be turned down when I get the chance.These will weigh a bit more and give me another tunning option.The Id is perfect and no step drill will be needed.
I also picked up some really thick washers to use in the rear wheels. I didnt snap any pics but the step drill came out again and a press fit was in order.
hotwheels000 is offline   Reply With Quote
Old 01-07-2012, 12:05 PM   #31
Erik D_lux's Avatar
Wow! That is a great idea!
Old 01-12-2012, 11:59 AM   #32
Nicklepimp's Avatar
Great tip on changing the width spacers/foams. Pretty cool that you don't have to take apart the bead to do it.
BTW I took a couple measurements of the rear xr10 axle with the hubs I had. SLW hubs with Rovers outside of tires:
.475=10.25"
.600=10.5"
I'm assuming the other hubs would be just .25" increments from those.
Nicklepimp is offline   Reply With Quote
Old 01-12-2012, 12:12 PM   #33
Erik D_lux's Avatar
Awesome. Thanks for the info!
Old 02-19-2012, 01:00 PM   #34
Erik D_lux's Avatar
Running a bit behind on these but I should have more ready to go by Tuesday.
Old 03-17-2012, 03:49 PM   #35
I received the rims, super easy to monter.Par cons they saw I ought to hold the flange to the hub.
Thank you Cyril.
cyril 45 is offline   Reply With Quote
Old 03-18-2012, 07:11 PM   #36
Erik D_lux's Avatar
CF faces!
I will be adding these to my store ASAP.
With the CF face, you can now have your DLUX wheels UNDER AN OUNCE when used with aluminum hardware.
Old 03-18-2012, 07:22 PM   #37
those are SICK!!!
53 willys is offline   Reply With Quote
Old 03-25-2012, 07:32 PM   #38
WTF
Easiest beadlocks that I've ever assembled. Thank you for a great product.
WTF is offline   Reply With Quote
Old 03-27-2012, 10:23 AM   #39
I love my wheels..... light weight and tough.
Great products followed up by great service!
Mad Dawg is offline   Reply With Quote
Old 04-15-2012, 07:30 PM   #40
Just made an order. Is it ready yet? I feel like one of my kids. Are we there yet?
Grimreeper is offline   Reply With Quote
DLUX 2.2 AND 1.9 wheels - Similar Threads
**New** DLUX Wheels Erik D_lux Tires and Wheels 625 10-06-2015 06:59 PM
~~ Stormin's Test Set of 2.2 Dlux Wheels ~~ Stormin2u Tires and Wheels 27 12-21-2011 08:19 PM
** NEW** 1.9 Dlux Delrin Wheels Jslick Tires and Wheels 30 12-18-2011 07:42 PM
DLUX T-Shirts Erik D_lux Vendors Miscellaneous 0 02-08-2011 11:26 PM
You may edit your posts
