08-14-2013, 11:06 AM | #101 |
Rock Stacker Join Date: Dec 2011 Location: canada
| Re: DLUX 2.2 AND 1.9 wheels
"When assembling the wheel make sure you use all 6 hub bolts. If there is a weak spot of the wheels, this is it." and the first pic you can seea hub .... has only 3 screws in the hub. haha that's funny! |
08-14-2013, 11:17 AM | #102 | |
| Re: DLUX 2.2 AND 1.9 wheels Quote:
Many have run 3 screws and been fine. I am still sitting at ZERO failures on my wheels as far as I know, even with people running 3 screws. I had a hard time finding a CF that I liked in the beginning. With some of the lesser quality CF, if I ran less than 6 screws, it would be a quick death. With the CF that I use now, it may be a non issue but the point is that I could make a low quality CF survive with 6 screws but not with 3. Thats how much it mattered. I also dont think most are as hard on a rig as I am so it may be a moot point. | |
08-14-2013, 11:28 AM | #103 |
I'm with Erik on this one. The CF in his wheels is exceptional quality! I have had mine for over a year now an talk bout taking some abuse. I'm also harder on my rig then most I know. Boarder line reckless(when in a bind or tight situation).. some thing is goin to give or my rig is coming out, period! I only use an have only ever used 3 hub screws in his wheels. Great stuff Erik! :thumbup: |
08-22-2013, 03:07 PM | #104 |
just got my set , they look great. as I cheaped out and only got g-10 not carbon, I will heed your advice and run all 6 hub screws thanks again erik! |
09-11-2013, 12:09 PM | #105 |
Newbie Join Date: Feb 2010 Location: Scottsdale AZ
Order placed Now I feel like I like little kid counting down the days till Santa gets here! |
09-11-2013, 07:16 PM | #106 |
They're on their way so you should have them soon. Thanks for the order! |
11-06-2013, 02:38 AM | #107 |
Rock Stacker Join Date: Jan 2012 Location: La Verne
Does the dlux wheel weight system work with SLW hubs?
11-06-2013, 07:06 AM | #108 |
No, you would need a DH hub so the weights fit around it.
11-11-2013, 05:58 PM | #109 |
Newbie Join Date: Sep 2013 Location: Edmonton
What is the inner diameter of the 2.2 beadlock wheels?
11-12-2013, 12:07 PM | #110 |
Just a bit over 1.75"
11-12-2013, 03:41 PM | #111 |
Thank you sir
01-02-2014, 10:36 AM | #112 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
Hmmm, a little confused here. Your wheels bolt up to both DH and SLW hubs. I thought they were the same except for the slug notches, but not so. The 6-bolt patterns are very close, but not close enough to swap them in VP wheels. So how can you fit both? Slightly oversize holes or something?
01-02-2014, 10:48 AM | #113 |
The bolt patterns are close enough that you can work the hub screws into my wheel face with just a touch of effort. To be clear, the wheels are made for an SLW hub, but can work pretty easily if you want them do with a DH hub. |
01-08-2014, 09:57 AM | #114 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
I am looking at building another AR60 sporty and I want a set of wheels that will work with different set ups. I like both wheels here Bead-lock and glue-on. The bead-lock is double the price of the glue-on so my question is this.... ...If I go with the glue style wheels, what will it take to unass the beads if I need to change the tires? Will it be beneficial to simply go with bead-locks or do the glue-on offer some versatility by removing glue. Lastly, do you still offer Hunter Orange faces? |
01-08-2014, 11:31 AM | #115 |
I am not sure to be honest. I run all beadlocks except my super and there is not much need to un glue those. If you search the tire/wheel section, you can see quite a few posts about the subject. I have even seen a product that removes glue. These guys have a Hunter Orange that I can order. Only problem is cost since I have a $25 min order, its worth while to order many wheels or get some friends that want custom colors to bring your personal cost down. G10 Colors & Textures - AKS™ |
01-08-2014, 11:35 AM | #116 |
Thanks for the fast response and the response to my message as well. I'm itching to get my crawler going. Once I choose a chassis I can afford that is - LOL By the way, will your internal weight system work with both the beadlocks and glue on? Last edited by redsawacs; 01-08-2014 at 11:44 AM. |
03-12-2014, 12:04 PM | #117 |
I figured everybody would like this news...... Price of CF wheels has dropped pretty dramatically! I have a new way of doing things and you get to reap the rewards. |
03-16-2014, 09:01 AM | #118 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
What does "Beadlock width (Glue on width)"?? And you get to choose from alot off options.. I will have bedlockrings,do I need to inform off the bedlock width then?? |
03-16-2014, 08:37 PM | #119 |
The beadlocks make the wheel wider. So, if you use a 1/2" spacers on a glue on wheel, they will be 1/2" wide. If you use a 1/2" spacer on a beadlock wheel, they will be .780 wide.
03-29-2014, 11:04 PM | #120 |
Pebble Pounder Join Date: Aug 2010 Location: Sioux Falls, South Dakota
What is the thread size of the screws that thread into the spacers?
DLUX 2.2 AND 1.9 wheels - Similar Threads | ||||
**New** DLUX Wheels | Erik D_lux | Tires and Wheels | 625 | 10-06-2015 06:59 PM |
~~ Stormin's Test Set of 2.2 Dlux Wheels ~~ | Stormin2u | Tires and Wheels | 27 | 12-21-2011 08:19 PM |
** NEW** 1.9 Dlux Delrin Wheels | Jslick | Tires and Wheels | 30 | 12-18-2011 07:42 PM |
DLUX T-Shirts | Erik D_lux | Vendors Miscellaneous | 0 | 02-08-2011 11:26 PM |
