02-15-2012, 06:02 PM | #1 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
| GCM M-Series, Trailer, and Scale truck 1.50 CenterlineRims
The JKRC team and GCM Racing have brought together aluminum, CNC machines, and innovation. And we present, the M-Series Centerline rims, with adjustable offset. (... Also makes a great setup your Offroad 1.55 tires for Scale Truck or Trailer ...) From Design to Finished goods, these wheels have a dual purpose. First, they must be a direct fit for M-Series and 12mm Hex mounting, and second, they must be adjustable for offset changes. The latter feature also allows for narrowing and widening the rim on demand, something that just isn't offered any where else. As you can see above, the wheel is assembled in sections, and these sections allow the component stacking order to be changed at will. If you want zero offset, then use as shown. If you want 3.5 or 7mm offset, then simply change the order of the assembly. There's nothing to it, no extra components are needed. Just a #1 phillips screwdriver, and about 1 minute. Below is a series of pictures. These show you mounting on my stock hex, from zero offset, then +3.5mm, and up to +7mm offset in order, and you can see the effects on the car. In this case the +3.5 looks amazing on this thing! And now on the car from zero, +3.5, and +7mm The hardware is 2-56 flathead stainless steel screws, and hold the layers very tightly with no effort. All the aluminum parts are protected by a tough anodize finish, making tire removal and gluing easy so you can reuse these rims long after your tires wear out. And with the aluminum and stainless hardware the whole wheel is a surprisingly light combo ready to race. Orders available only at gcmracing.ca |
02-15-2012, 06:24 PM | #2 |
RCC Addict Join Date: May 2010 Location: Midwest
| Re: GCM M-Series, Trailer, and Scale truck 1.50 CenterlineRims
Wow.. That's a cool idea on a popular classic wheel design. Great Job GCM! |
02-16-2012, 07:46 PM | #3 |
Quarry Creeper Join Date: Mar 2006 Location: laval
look really cool on the mini great job |
02-17-2012, 05:54 PM | #4 |
Any chance you would make Centerlines for a 2.2 tire? I like those.
02-17-2012, 06:17 PM | #5 |
Could happen. I'll look into it.
02-17-2012, 06:30 PM | #6 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
that is really awesome. and i would also love that style in a 2.2 as well. nice mini! |
02-17-2012, 08:36 PM | #7 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Super job! I love 'em!
02-18-2012, 04:05 PM | #8 |
Pebble Pounder Join Date: Jul 2008 Location: bedrock
could you make them look like the american racing outlaw 2's , with the holes around the outside of the wheel???
02-18-2012, 04:57 PM | #9 |
Here's one with 0mm setup up front and 3mm in the back, it's an ABC Hobby Celica body. and here's one with the same 4 wheel kit, only with the front spacers out, and put out back, and longer screws in the back. Now sporting F1 rears and custom skinnies up front. |
03-17-2012, 10:56 PM | #10 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
| Re: GCM M-Series, Trailer, and Scale truck 1.50 CenterlineRims sweet love the wheels..i have a tamiya vw bug that these would be the bomb on..love the celica body too..my next abc body that looks pretty badass..whats that second car/chassis with the straight axle |
03-27-2012, 08:05 AM | #11 |
Nice! That celica body looks even better with those wheels ..and what is that straight axle car? looks mean with that fat & skinny setup! |
03-27-2012, 08:13 AM | #12 |
Thanks for the comments. That jobbie is a home built thing with a velineon BL and a semi rear axle linked. Cool! |
03-27-2012, 08:42 AM | #13 |
Rock Crawler Join Date: Oct 2009 Location: Washington State
And this is exactly why you get my money! Keep up the innovation. |
GCM M-Series, Trailer, and Scale truck 1.50 CenterlineRims - Similar Threads | ||||
GCM 4TEN Leaf-Spring Scale Truck Chassis | Generis | Chassis and Suspension | 34 | 12-30-2016 06:49 AM |
GCM Scale Truck Conversions for Axial and Venom | Generis | Chassis and Suspension | 12 | 04-06-2013 08:25 AM |
GCM MetalHead Axle Thread-For Axial Scale Truck | Generis | Axles, Trannys, T-case | 43 | 03-21-2012 07:30 AM |
GCM Cast Mercedes G-Series 1.9 Wheels | Generis | Vendors Tires and wheels | 4 | 08-13-2010 10:52 AM |
