05-24-2015, 03:36 PM | #181 |
| Re: DCW Made to Order Delrin Wheels
Busy 1.9 weekend! For Codyboy: For Solid94: For trialpsycho: |
05-25-2015, 09:14 PM | #182 |
For CBE RC Fab's YetiX... |
05-31-2015, 07:36 PM | #183 |
Say whaaaaa? A set of 6 1.9's for WesTX. 2 @ 1" wide, and 4 at a whopping 2.5" wide. |
05-31-2015, 08:01 PM | #184 |
Pebble Pounder Join Date: Apr 2013 Location: in the shop
Holy wide wheel batman
06-01-2015, 08:13 AM | #185 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
| Re: DCW Made to Order Delrin Wheels |
06-01-2015, 09:58 AM | #186 |
Your order has been shipped, and your build thread has been subscribed. Thanks again! |
06-10-2015, 05:50 PM | #187 |
I wanna be Dave Join Date: Jul 2008 Location: Southwestern, Ohio
Duuuuuuuuuude, thanks for the fabulous wheels! I will get a pic or two up when I get them mounted. In the mean time feel free to post a pic or two if you wish. Dan |
06-10-2015, 07:09 PM | #188 |
Newbie Join Date: Apr 2009 Location: Randleman
Will your wheels in glue on work well in U4 or should I go beedlock? Sent from my iPhone using Tapatalk |
06-10-2015, 07:31 PM | #189 |
06-10-2015, 07:35 PM | #190 |
| Re: DCW Made to Order Delrin Wheels Honestly, delrin can be a little tricky to glue things to, but they will hold just as well as any other glue on wheel. The trick is to scuff the bead groove up really well, make sure its super clean, and use a thin ca glue. If you don't give the glue a good surface to grab on to, you'll peel the beads the first time out. I use 80 or 100 grit paper cut into a strip just big enough to fit in the groove, wash with a little soap and water, let them dry, then follow up with alcohol.
06-10-2015, 07:37 PM | #191 |
Biggins wheels... |
06-10-2015, 07:48 PM | #192 | |
| Re: DCW Made to Order Delrin Wheels Quote:
Understand exactly what you're saying as I've done my share of off-road racing in the past and always glued then as well..... Was just curious as it seems there is more tire "abuse" in U4 racing, tho there is ALOT more sidewall on these tires Sent from my iPhone using Tapatalk | |
06-10-2015, 07:53 PM | #193 |
To my knowledge I've only sent out 4 sets intended for U4 use, so I guess its a time-will-tell kind of thing. As long as they are prepped and glued right, I can't see them doing any worse than regular nylon wheels.
06-11-2015, 06:49 AM | #194 |
Sounds good. Looking forward to getting some Sent from my iPhone using Tapatalk |
06-26-2015, 11:51 AM | #195 |
Newbie Join Date: Apr 2014 Location: Burlington NJ
| Re: DCW Made to Order Delrin Wheels Soooo are these a custom, won't make them again, set of wheels? I love how they look like corvette wheels and would look great in a 2.2 with MTHead rings on my yeti. Please let me know. Thanks. Sent from my iPhone using Tapatalk |
06-26-2015, 12:13 PM | #196 |
Pm on its way.
07-02-2015, 08:21 PM | #197 |
Got my badass DCW "vette" wheels yesterday and installed them on Copperhead (my yeti) today. These wheels are sooo sick! Thanks for the awesome wheels! I love em!! Sent from my iPhone using Tapatalk |
07-02-2015, 08:39 PM | #198 |
Some 2.2 beadlock/glue wheels by the duuuuuuuude. |
07-02-2015, 08:47 PM | #199 |
Look like a "smoothly" tractor trailer wheel... Sent from my iPhone using Tapatalk |
07-11-2015, 09:40 PM | #200 |
I threw some Vanquish Brakes behind my awesome DCW wheels and now the wheels stand out and look even better!! I've bashed the crap out of em and so far they have been great and held up to my abuse! Sent from my iPhone using Tapatalk |
DCW Made to Order Delrin Wheels - Similar Threads | ||||
Steering/Suspension Aluminum, Titanium, Delrin links. Custom made | Erik D_lux | Chassis and Suspension | 72 | 07-31-2020 05:28 PM |
Ultralite Delrin D-Mount from DCW | Duuuuuuuude | Chassis and Suspension | 239 | 08-05-2014 09:49 PM |
Testing Interest: Made to order wheels | Duuuuuuuude | Tires and Wheels | 52 | 05-19-2014 08:42 PM |
