Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: New 1.9 Scale Beadlocks from GCM Racing
Old 05-28-2015, 08:23 PM   #1
Default New 1.9 Scale Beadlocks from GCM Racing
Hiya, we have a ton of new wheel stock >>HERE AT THIS LINK<< so swing by and take a look at the new 1.9 offerings.
All of these 1.9 Beadlocks are now standard Hex mount, all of them are 6 Lug mounting, and we have some polished aluminum and Black Anodized finishes available.
Here's some wheel pics to lay it onto your retina:
GCM Racing - 5-Slot Scale Beadlock 1.9 Rim
GCM Racing - 8-Hole Scale Beadlock 1.9 Rim
GCM Racing - 8-Hole Scale Beadlock 1.9 Rim BLACK
GCM Racing - Baja Detroit BL 1.9 Rim
GCM Racing - 12 Spoke Beadlock 1.9 Rim
Generis is offline   Reply With Quote
Old 05-28-2015, 09:50 PM   #2
Suck it up!
Duuuuuuuude's Avatar
Default Re: New 1.9 Scale Beadlocks from GCM Racing
I got to see the slots up close at Disney. Very nice.
Duuuuuuuude is offline   Reply With Quote
Old 06-16-2015, 10:34 AM   #3
Got some nice pics of this rig with the 12 Spoke rims. I like these. Very classy!
Old 06-16-2015, 11:17 AM   #4
Very nice!!!
Bogncrawl is offline   Reply With Quote
Old 06-28-2015, 09:49 AM   #5
I am so in! I've got a set of 12 spokes on its was to me as I type.
Alexander_0_1 is offline   Reply With Quote
Old 07-27-2015, 05:24 PM   #6
Look nice, but do they fit VP six bolt hubs? Obviously the five lug style don't, but what about the six lug wheels?
Old 07-27-2015, 06:42 PM   #7
None of GCM rims fit VP hubs.
Old 07-28-2015, 10:02 AM   #8
Do they fit any other hub pattern, RC4WD, Hot Racing or?
Old 07-28-2015, 02:41 PM   #9
They do not. We provide a mounting hub for each wheel in the kit, there's no additional parts to purchase.
The bolt spacing on these other manufacturer's hubs is much wider than ours, and we opted for the most scale looking setup possible, and so we offer a smaller bolt spacing than all the other manufacuturers.
Old 07-28-2015, 02:59 PM   #10
OK I see now and your hex adapter allows for more wheel dish while not making the wheels stick out too far, thanks.
Yes, the slots are nice.
Old 08-13-2016, 05:40 PM   #11
What size is the hardware used in your wheels?
josh6575 is offline   Reply With Quote
Old 08-14-2016, 05:41 AM   #12
All our wheels are 2-56 hardware. 3/8 long in the beadlock and 1/4 long in the rotor.
Old 08-14-2016, 03:04 PM   #13
Thank you, Generis
I am using two different axles and trying to get the track width to match. Any chance I could get the coordinates of the bolt circle? I want to make some brass spacers.
Old 08-15-2016, 08:41 AM   #14
Sounds smart to make a brass spacer. A bit of outside weight is good, especially centered on the axle like that.
The bolt circle is not in my brain at the moment, I know we use a 0.086 diameter hole though. 3/16 center hole. We have spacer kits in aluminum that are 3mm more offset if that helps.
Old 08-15-2016, 04:00 PM   #15
Thanks for the info. I need to get the wheels bumped out 3/8 on each side at the front. I thought about using 3 of your spacers on each side. With those tiny little bolts I think they will hold up a lot better being one piece. I am surprised you do not sell different widths.
New 1.9 Scale Beadlocks from GCM Racing - Similar Threads
GCM Racing Stickers and Shirts Generis Vendors Miscellaneous 1 05-27-2013 08:29 AM
You may edit your posts
