Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: *New* DCW Delrin Wheel Thread
Closed Thread
Old 11-12-2015, 09:39 PM   #41
Default Re: *New* DCW Delrin Wheel Thread
I believe the circle indent around the non threaded holes are slightly bigger? I might be wrong...
fr8cture is offline
Old 11-12-2015, 11:40 PM   #42
Location: Turn the mayflower around.. it will never work
I used cap head screws on the actual ones for that reason. I'm sure ones that use the scale hardware guess? Lol
Thankw, I really think the bright silver helps the blue pop!! It sucks, chris did such a awesome job on the machining and here I go tossing tires and big goddy rings to hide most of it. Lmao
JokersWild is offline
Old 11-12-2015, 11:42 PM   #43
Nah.... hit em with caliper.... same size
Old 11-12-2015, 11:44 PM   #44
Originally Posted by Chris_The_Battery_Man View Post
I read on your site that these work with axial rings? Do you have any pictures? also, what aprox would a 1.9 and a 2.2 wheel weigh? I know the design can effect the weight a little
Chris I got you a weight...... one of my 1.9 wheels with blank face 1.45 oz
Old 11-12-2015, 11:45 PM   #45
Oh interesting. Maybe thats a good idea that they could change. Shouldnt be that noticeable unless you look for it.
fr8cture is offline
Old 11-15-2015, 04:13 PM   #46
Originally Posted by bilinvic View Post
Dumb question of the day.....When you are changing the tires, how do you know which of the outside scale bolts are the real ones without having to test everyone of them?
I have those same rings. I started with putting a full length stud (7mm) in the hole that lines up perfectly with one of the five spokes, only one will! Then since the DCW wheels are twelve hole you'd use a faux stud every other hole. My LURC wheels use six 7mm studs to hold the front ring in place, so only used 7mm studs every fourth hole the rest a faux.
Alexander_0_1 is offline
Old 11-16-2015, 11:52 AM   #47
Meh...... 6 actual bolts be fine...... other 6 are incase any strip
Old 11-17-2015, 12:34 PM   #48
I hear ya! then by That same method, I could ask for all 24 holes to be tapped, and end up with 3 extra sets of hole, you know just in case any strip...
Old 12-06-2015, 02:57 PM   #49
Maybe it's just because I'm a mangy palindrome that is fond of Mexican cuisine but the machining on these wheels seems like magic to me. It would be pretty badass if you made a short video documenting the process for your simple feline fans! Please haha
tacocat is offline
Old 12-06-2015, 05:37 PM   #50
Suck it up!
Duuuuuuuude's Avatar
Twisters are now available in 2.2!
DCW Crawlers - Home
Maybe someday.
Duuuuuuuude is offline
Old 12-06-2015, 05:38 PM   #51
snapon boy's Avatar
Don't share to many of your secrets
snapon boy is offline
Old 12-09-2015, 09:37 PM   #52
Didn't see if it was asked here or specified on the site. Will the 2.2 wheels clear the VP knuckles chubs for the wraith, and will the 1.9 wheels clear the VP high steer knuckles? Thanks in advance.
bryco13 is offline
Old 12-09-2015, 09:39 PM   #53
snapon boy's Avatar
Dude can adjust the back spacing to make that happen I'll bet.
Old 12-09-2015, 09:43 PM   #54
Suck it up!
I've got VP high steer knuckles on my Bomber, the 2.2 wheels clear just fine. Not sure on the 1.9's though...but I can check.
Old 12-09-2015, 10:00 PM   #55
Suck it up!
Both wheels are shown with standard backspacing and .225 hubs.
1.9 with LURC inside ring. Close, but it clears.
2.2
Old 12-09-2015, 10:20 PM   #56
I'll be ordering some 2.2's tomorrow. I'll pm you in the morning sir!
bryco13 is offline
Old 12-13-2015, 08:04 AM   #57
Nope..
Brainstain's Avatar
I got my 2.2 Twisters yesterday. I love them.
Brainstain is offline
Old 12-13-2015, 08:05 AM   #58
Suck it up!
You're mounting them backwards?
Old 12-14-2015, 05:19 PM   #59
Suck it up!
Got a few things in the Used/Clearance/One-off section that are ready to ship. No waiting!
Used/Clearance/One-off - DCW Crawlers
Old 12-28-2015, 01:12 PM   #60
Here's a few pics of my DCW Wheels!! (1.9 10 Hole, custom backspacing)
All packaged up:
A shot of them out of the bag, pics don't do these wheels justice. Excellent machining and a really nice looking wheel!
Weight in ounces:
Weight in grams:
Couple more pictures of the wheels!
All mounted up with 1.55 Growlers, Lock Up beadlock rings and scale hardware:
VMGontheRocks is offline
Closed Thread
*New* DCW Delrin Wheel Thread - Similar Threads
DCW Made to Order Delrin Wheels Duuuuuuuude Vendors Tires and wheels 208 09-19-2015 03:15 PM
Ultralite Delrin D-Mount from DCW Duuuuuuuude Chassis and Suspension 239 08-05-2014 09:49 PM
Delrin and thread lock? CrazyNick General Crawlers 8 03-09-2012 05:45 PM
Delrin/Thread Lock????? Gimp Tires and Wheels 7 01-06-2011 07:56 PM
You may edit your posts
