Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: F's Low-CG 2.2 Beadlock Wheel & Low-CG Weight & Carbon Fiber Wheel
Old 07-30-2013, 09:06 AM   #1
Default F's Low-CG 2.2 Beadlock Wheel & Low-CG Weight & Carbon Fiber Wheel
The beadlock wheel is design for the Low-CG weight. It works with the SLW hub.
Each pair wheel includes
* 2x1.5mm carbon fiber beadlock front rings
* 2x1.5mm carbon fiber beadlock back rings
* 4x POM plates
* 6x 1.5mm carbon fiber hub spacers
* 18x15mm standoffs
* 18x18mm standoffs
* 18x20mm standoffs
* no screws
Each pair is $68 including US domestic USPS first-class mail.
+$10 to get 26xM3-8mm and 34xM3-6mm blue aluminum screws. It is only for the wheel not for the hub.
noahzhou is offline   Reply With Quote
Old 07-30-2013, 09:06 AM   #2
Default Re: F's Low-CG 2.2 Beadlock Wheel & Low-CG Weight & Carbon Fiber Wheel
F's Low-CG Weight
* Lower than normal weight
* Work with RcBros Knuckle Weight Holder
* 3mm thickness, 24g for one
* Only work with F's Low-CG 2.2 Beadlock Wheel
6 is $35 including US domestic USPS first-class mail.
8 is $45 including US domestic USPS first-class mail.
Old 07-30-2013, 09:08 AM   #3
F's glue Carbon Fiber Wheel
Old 07-30-2013, 09:13 AM   #4
Old 07-30-2013, 09:27 AM   #5
Old 10-04-2013, 11:49 PM   #6
What foams can we use with the beadlock wheel? Good old Crawler Innovations. These wheels look set by the way and I like the price also.
Diablo666 is offline   Reply With Quote
Old 10-06-2013, 07:11 PM   #7
I use CI Single Stage Double Deuce Single Stage Double Deuce Pair (2)
It works great
Old 11-11-2013, 01:04 AM   #8
These things look sweet. There isn't a price posted for the glue on wheels for the rear or any ordering instructions...
Rocknut is offline   Reply With Quote
Old 12-05-2013, 08:01 PM   #9
Noah these wheels are sick! and are my favorite wheels so far. how have I not noticed them untill now
chris.martell is offline   Reply With Quote
Old 12-30-2013, 11:14 AM   #10
www.ottsix.com
Very smart design
crawl-o-matic is offline   Reply With Quote
Old 03-04-2016, 05:01 AM   #11
Ok, correct me if I am wrong, but it appears that the glue wheels will not work with the weights, and that the inboard weight will not work with either.
Marth is offline   Reply With Quote
F's Low-CG 2.2 Beadlock Wheel & Low-CG Weight & Carbon Fiber Wheel - Similar Threads
Low Boyz 2.2 Weighted Pendulum Beadlock Wheel climbingfireman` Tires and Wheels 5 02-18-2010 10:58 PM
You may edit your posts
