Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: Motoworx Racing's New 2.2 5 Spoke Wheel
Old 02-15-2016, 06:56 PM   #1
Default Motoworx Racing's New 2.2 5 Spoke Wheel
Product Description
New February of 2016 the 2.2 5 Spoke SLW wheel
Whats New:
SLW style wheels have the standard detatchable hex hub mounting specs. Therefore an additional mounting hub is requiered for each wheel
2mm hardware is used on the beadlock rings and 4-40 screws are included for the hex hub mounts.
The outer ring screw hole pattern on the 2.2 5 Spoke SLW wheel has a 16 hole or 8 hole mounting option. This allows for the use of an 8 hole outer ring in comp situations for quick tire changes or a 16 hole outer ring for scale effect.
Excess material has been machined out on side walls on the inboard wheel walls for weight savings without structural compromise
2.2 5 SPOKE SLW WHEEL |
motoworx is offline   Reply With Quote
Old 02-15-2016, 11:03 PM   #2
Default Re: Motoworx Racing's New 2.2 5 Spoke Wheel
Do you have any pics with the raw aluminum wheel with a black outer ring without the "teeth"? Like the one shown on the black wheels.
Sent from my SM-G900V using Tapatalk
YeeP is offline   Reply With Quote
Old 02-16-2016, 09:09 AM   #3
Here you go.
Old 01-08-2017, 04:06 PM   #4
Dear motoworx, How these wheels compare to Vanquish Method 2.2? I have heard Vanquish Method wheels are not the true 1'' and 1.250'' can, making it difficult to use the highly regarded Crawler InNovations foams and wider tires such as the PitBull RockBeast. What say yours? I am very interested in your wheels and I would like to run either PitBull RockBest ii or Pro-line Interco TSL SX Super Swamper XL 2.2" G8 tires. Please let me know more information and Thank you so much.
Teng is offline   Reply With Quote
Old 01-11-2017, 03:35 PM   #5
My 2.2 wheels measure 1.1" in width without the bead rings assembled. If you need wider I make wheel wideners which would make the wheel about 1.450". If that doesn't work for you we can go the custom route and get whatever your wallet allows.
And of course my wheels are the best and 100% made in USA!
Hope that helps
jake@motoworxracing.com
Motoworx Racing's New 2.2 5 Spoke Wheel - Similar Threads
Motoworx Racing's All New 3.8 Wheel motoworx Vendors Tires and wheels 10 04-14-2016 07:16 PM
what scale hardware from LockedUp for MotoWorx 2.2 8 Spoke SLW wheel? ussprinceton2004 Tires and Wheels 1 09-12-2014 08:47 PM
Motoworx Racing's new 1.9 design motoworx Vendors Tires and wheels 36 10-18-2012 06:42 PM
Motoworx Racing New 8 spoke wheel 2.2 motoworx Vendors Tires and wheels 10 11-04-2010 03:55 PM
Motoworx Racing's New 2.2 wheel design. 1" wide for Axial, Losi motoworx Vendors Tires and wheels 6 05-26-2010 03:25 AM
You may edit your posts
