Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: A08™
Old 03-11-2016, 04:02 PM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default A08™
Our AO8™ wheels are our most scale wheel yet!
AO8™ (8 Lug)
These wheels feature a tighter 8 lug pattern for more "face". This means more detail and a better look on each design:
Since the flanges are detachable ... you now get the option to play with track width:
We even designed new M2 "Mag" Acorns to drop a scale bomb on everyone!
Every AO8™ wheel is also Easy Mountฎ compatible so your foam and tire changes are a snap!
Stay tuned for new designs and color options soon ... and thanks for reading.
Locked Up is offline   Reply With Quote
Old 03-13-2016, 07:41 PM   #2
~THE SCALE SHOP~
Default Re: A08™
Nice!
will the scale lug tool clear the scale hub?
STANG KILLA SS is offline   Reply With Quote
Old 03-14-2016, 11:48 AM   #3
Locked Up's Avatar
Default Re: A08™
Originally Posted by STANG KILLA SS View Post
Nice!
I'm glad you reminded me!
The Mag Acorns can use the smaller 2mm hex socket drivers, like the 2mm HD Socket Driver.
That will clear our Ultra Front hubs and our Ultra Rear Hubs with the Mag Acorns.
Our older, regular scale hub will still fit in there, but you'd need to put the mag acorns on first.... and the older acorns and older scale hubs will be too tight together.
You may edit your posts
