Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: 2 wheel drive bearing type slw compatible hubs
Old 05-23-2016, 07:54 PM   #1
Default 2 wheel drive bearing type slw compatible hubs
Compatible with all industry standard SLW style wheels. These enable you to run any SLW style wheels on a 2 wheel drive type RC vehicle. Each hub require 2, 11mm OD X 5mm Thick bearings.
Bearings not included
4-4o screws not included.
motoworx is offline   Reply With Quote
Old 05-23-2016, 07:54 PM   #2
Default Re: 2 wheel drive bearing type slw compatible hubs
Back in stock!
Old 05-23-2016, 09:08 PM   #3
Using these for a trailer build! Only thing is I used bearings with a 4mm ID so I could use 4mm studs and standard lock nuts.
Drilled out RC4WD wheel to accept SLW pattern.
HahnsB2 is offline   Reply With Quote
Old 07-17-2016, 09:09 PM   #4
Cool idea!
BC-Brian is offline   Reply With Quote
Old 03-28-2017, 01:49 AM   #5
Will they work on the front axle of a Tamiya Subaru Brat axle ??
what is the offset of the hub ??
kgb424 is offline   Reply With Quote
2 wheel drive bearing type slw compatible hubs - Similar Threads
Inexpensive 2.2 beadlocks compatible with VP SLW Hubs infodragon Tires and Wheels 0 09-15-2014 06:01 AM
You may edit your posts
