Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Tires and wheels
Thread: Uh oh...new pit bulls coming!
Old 07-24-2017, 06:42 PM   #101
Default Re: Uh oh...new pit bulls coming!
Got my 1.55 rockbeast's today! I dislike wagons but I had a set laying around and they work well on the truck and with the tires. Can't wait to get out and test em. They got ci foams right away as I had a set laying around just waiting for these.
lilws6 is offline   Reply With Quote
Old 07-25-2017, 03:43 PM   #102
I should note that mounting the XORs on my wheels with the CI foams was 10x easier than with the stock foams, since the CI dual-stage inners are actually shaped with the bead/wheel in mind. I had forgotten about that part...
Sneetches is offline   Reply With Quote
Old 07-27-2017, 02:39 PM   #103
I'll just leave this here.
808DA6 is offline   Reply With Quote
Old 07-27-2017, 07:01 PM   #104
What wheels have the 1.55 rockbeast been successfully mounted on, I just tried a set of rc4wd dick cepek torques and it was pretty bad with stock foams
kunas is offline   Reply With Quote
Old 07-27-2017, 07:34 PM   #105
Rc4wd wagons with ci foams
Old 07-28-2017, 06:06 AM   #106
Another new PB tire:
Braven Ironsides - 4.19 x 1.3 x 1.9
svt923 is offline   Reply With Quote
Old 07-28-2017, 06:32 AM   #107
Funny they basically released their ATV tires as scale tires, but those look convincing enough to be an A/T truck tire.
Old 08-08-2017, 12:47 PM   #108
Tested out my new 2.2 PBX today. Very pleased so far.
Desmo is offline   Reply With Quote
Old 08-08-2017, 01:50 PM   #109
Moderator
JatoTheRipper's Avatar
Eh. A/T truck tires aren't typically nearly as wide as they are tall. I'm sure they will work well though.
Old 08-09-2017, 02:25 PM   #110
Not sure what you mean? I'm running 285/75R16 A/Ts on the 1:1 right now, as far as I see the proportions are pretty accurate.
Old 08-09-2017, 02:36 PM   #111
Moderator
In the photo above they look super wide like ATV tires.
Old 08-09-2017, 02:41 PM   #112
100% that's because of Pitbull's foams, my XORs did the same thing and it made them a PITA to mount. CI foams make them look normal again.
Old 08-09-2017, 03:09 PM   #113
Moderator
Interesting. I am a big fan of the "old" dual stage foams that Pitbull includes in the OG 1.9 Rock Beasts.
The new single stage Pitbull foams included with the new Alien Kompound tires don't seem to have mass appeal. Judging from this forum and the Facebook groups about half of the people still have to buy CI foams for their application. Pitbull should keep the foams and lower the price. I mean the foams were part of their justification for the high pricing. The tires are even made in Taiwan. Were Pitbull RC tires always made there?
Old 08-09-2017, 04:28 PM   #114
Hey sneetches, what size/cut foams did you buy for the XOR's?
shiftauto is offline   Reply With Quote
Old 08-09-2017, 04:30 PM   #115
CI 4.25" dual stages, medium front/firm rear right now.
Old 08-09-2017, 04:32 PM   #116
The 4.25 made em taller and skinnier? I thought they're 4.5" tall
Old 08-09-2017, 05:44 PM   #117
The 4.25 is not the height more rather for the weight of the truck
Old 08-10-2017, 10:46 AM   #118
Really? I thought the outer foams were more to the vehicle weight and the inners were tire height specific...
Old 08-10-2017, 12:00 PM   #119
From what I understand when you order them they have the 3options 4.25 being lightest and 4.75 heaviest truck. Then you have options for stiffness of foam. Which helps dial in the traction. I could be wrong though. I'm running 4.5 foams in my rb xl's. Soft front Med rear I believe.
Old 08-10-2017, 01:44 PM   #120
They all use the same sized outer (even the 1.55 Growler foams), its the inner closed-cell foam that changes height. It is based off the weight of the truck more than anything. Eddy (Nova's Ark) has a thread in this forum that has some general recommendations, as well as a video on YouTube that explains the foams (worth a watch). Worst case (or best) is call him directly and give him tire used, vehicle weight, and intended use and he will recommend a foam.
LSXGMC is offline   Reply With Quote
Uh oh...new pit bulls coming! - Similar Threads
1.9 Pit Bulls? kasey Tires and Wheels 3 10-09-2011 12:16 PM
new pit bulls i got them gasser55t Tires and Wheels 41 07-15-2010 08:16 AM
You may edit your posts
