![]() | #81 |
Rock Stacker Join Date: Oct 2009 Location: Sweden
My first car since Tamiya Holiday buggy ![]() Venom Creeper Novak Rooster Crawler + Fifty Five (combo) 2.4Ghz Radio (tested with Esky 4channel to my helicopter but I intend to use my DX7 and AR6100 (6 channel rx) and trick it with remote lock diffs and steering front and back I soldered an Y-cable that allows me to connect 2 LIPO'S at the time 2S 900Mah is what I have around...so 1800Mah will do for now - but I have already planned in adding a 3rd connector I flipped lower "Z-bend" links to allow more clearance Updatedpic ![]() http://www.youtube.com/user/MrKalaspuff Some tweaks after videos Moved rear supports in front of axle and removed skid (but put the supports back after deanodizing) Added weight to wheels I used 1.5 mm solder and cut it to 1meter lengths, 4 in each tire front and 2 in rear tires (1.5mm solder weights 9gram/meter) 199-207grams stock wheels 259/251grams after in front wheels 229/230 grams after in rear wheels I will buy 1meter aluminium rods and make some links myself...to allow BTA (behind the axle steering) Cheers - UndCon Last edited by UndCon; 10-30-2009 at 01:12 AM. |
![]() | #82 |
![]() | #83 |
Quarry Creeper Join Date: Oct 2009 Location: Indiana
I'll try to get pics on some rocks in the am. 60% chance of rain.:-( yes it has a nylint body ![]() ![]() Rear steer is made not bought. Home made servo mount and links. The main shaft is a 1616 easton x7 aluminum arrow. Last edited by GB's 05; 11-28-2009 at 12:26 AM. |
![]() | #84 |
Quarry Creeper Join Date: Sep 2007 Location: NE Ohio
Updated the Creeper with a new vinyl warp. I had a friend make up a vinyl wrap for the Creeper, with the sickest camo pattern.... Ohh Yea ![]() ![]() ![]() ![]() |
![]() | #85 |
Got the pics on the rocks yesterday. The pic of the broken c-hub didn't show up. ![]() ![]() |
![]() | #86 |
Newbie Join Date: Sep 2009 Location: Elizabethville
Been working on the Venom project for the past 2 months, finally got the paint on the body. Next step is to do some crawling outside... The virgin needs to be broke in. ![]() ![]() ![]() ![]() ![]() |
![]() | #87 |
Rock Stacker Join Date: Feb 2008 Location: on a rock
![]() | #88 |
Rock Crawler Join Date: Aug 2009 Location: San Antonio
Stage 2 Kit Mamba Max Pro LRP 21.5T 12T Pinion Hitec 645MG KO Propo 2.4GHz Panther Leopards Eritex Heavy Comp Wheels (Berg Offset Rear) (Axial Offset Front) FLM Diff Locker (Soon) FLM Shock Bodies (Soon) HR Knuckles (Soon) HR Axle Carriers (Soon) HR Rear Axle Lockouts (Soon) DOA Dig Loker (Ordered) |
![]() | #89 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
new updated pics taken today
![]() | #90 |
Rock Crawler ![]() Join Date: Nov 2009 Location: Wildwood
| ![]() http://i891.photobucket.com/albums/a...1111091014.jpg http://i891.photobucket.com/albums/a...1118090812.jpg http://i891.photobucket.com/albums/a...1119091158.jpg integy 55 turn motor traxxas xl-10 esc 2oz/each front. 1oz/each rear tired hacked and grooved front high clearance steering(prototype ![]() rear steer |
![]() | #91 |
Pebble Pounder Join Date: Nov 2009 Location: joliet
![]() | #92 |
Newbie Join Date: Nov 2007 Location: Indy
Here is my creeper thus far. CKRC Stage 2 Venom Dig FX-R 55T combo JR- 650 for now 3-cell lipo Castle BEC ProLine Chisels 12oz up front 8oz in rear revised skid plate ![]() ![]() ![]() ![]() Chad Indy, IN |
![]() | #93 |
RCC Addict ![]() Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
Here is my first crawler and first build, waiting on a hitec HS-5955mg steering servo, hitec HS-225MG dig servo, doa dig and 2ch punk rc dig switch, nova's ark 2 stage foams for rovers and 8oz weights in each front tire, remote diff lock kit for front diff and alloy diff case, hr rear lockouts, flm rear locker, cc bec set up to 6v, 2 x 7.4v 1300mah lipos wired in parallel. Should be finished in a few weeks. ![]() ![]() ![]() ![]() ![]() |
![]() | #94 |
![]() | #95 |
Newbie Join Date: Apr 2009 Location: Orange County
![]() | #96 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Well here is a quick pic of the new venom creeper as a roller ![]() Goodie list: FLM lockers FLM stub shafts FXR with 45t Rovers (white) with Peachy 1 memory Foams Berg wheels Traxxas red springs Spektrum DX3R 70mm upper links Hitec 645MG steering servo CC BEC ElectroFly 2200 2S 25C lipo Body and mods to come. ![]() |
![]() | #97 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
here's mine ![]() |
![]() | #98 |
Newbie Join Date: Nov 2009 Location: Anna
| ![]() Last edited by morrisj24; 12-04-2009 at 01:17 PM. |
![]() | #99 |
Newbie Join Date: Dec 2009 Location: winfield
here is mine. |
![]() | #100 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
Bog tony your pics dont work. Heres a poser I took in the first snow of the year! ![]() |
