Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: Venom compared to Axial
Old 01-08-2009, 01:09 PM   #1
'08 2.2 National Champ
Just Zach's Avatar
Default Venom compared to Axial
Hopefully this works out but I just picked up a Venom and am going to get it together today with a Reign Widemouth Chaos. If not it will go stock chassis but I only have today to get it done.
I'll compare stuff with Axial as I go.
Tranny is done
Just Zach is online now   Reply With Quote
Old 01-08-2009, 01:22 PM   #2
Just Zach's Avatar
Well, annoying issue # 1. One of the lower links wasn't threaded. Now I have to find my tap:-(
Old 01-08-2009, 01:24 PM   #3
OCCUPY RCC!
dezfan's Avatar
Great Z, I have a Creeper on the way, I'll let you find and fix all the bugs!
dezfan is online now   Reply With Quote
Old 01-08-2009, 02:11 PM   #4
Just Zach's Avatar
Well, I couldn't find my tap so I gave up and am going to try to use some bent links I have.
Also, 2 holes and the widemouth is going to work great.
Old 01-08-2009, 02:29 PM   #5
OCCUPY RCC!
dezfan's Avatar
Sexy!
I already dug my tap out of the tool box and have it sitting on the work bench, next.
Old 01-08-2009, 02:32 PM   #6
That tranny is HUGE!
2JSC is offline   Reply With Quote
Old 01-08-2009, 02:39 PM   #7
Just Zach's Avatar
Originally Posted by dezfan View Post
Sexy!
It was just one so hopefully its a fluke
Yeah, that's what I thought
Old 01-08-2009, 02:44 PM   #8
OCCUPY RCC!
dezfan's Avatar
Yeah, I'm not sure what the designers were thinking when they designed that colossal tranny. I thought for sure it was so a DIG unit could be added, but that looks to be an external unit as well?
Old 01-08-2009, 02:46 PM   #9
I don't see why they couldn't have built a dig into the housing... is there a spur in the there or is it all gear reduction? Does the pinion do all the gearing adjustments?
Old 01-08-2009, 03:49 PM   #10
chris4207's Avatar
It was to my understanding that they have a front and rear dig built in.
chris4207 is offline   Reply With Quote
Old 01-08-2009, 03:50 PM   #11
OCCUPY RCC!
dezfan's Avatar
That's the Losi.
Old 01-08-2009, 03:59 PM   #12
chris4207's Avatar
Yup your right, I just looked at a pic. It looks like it has about 8-9 gears inside.
Old 01-08-2009, 04:07 PM   #13
Just Zach's Avatar
Just to show how I attached the chassis
Old 01-08-2009, 04:11 PM   #14
Just Zach's Avatar
Here's a picture of the axles side by side. As I measure them the Axial is 102mm hex to hex. The Venom is 108mm hex to hex. It does come with fairly wide hexs though so I am thinking with some narrower hexes you could get rid of most of the difference if you wanted to.
They went together well though. Everything seems well made and they feel smooth. The locking/unlocking diff could be helpful. I hope to set mine up with the front on a servo to switch it.
With stock Berg wheel (same offset as stock Axial wheels) and Losi tire the width ends up at 10.5" It looks like the Venom wheels have more offset. I'll post up when I have them mounted.
Old 01-08-2009, 04:37 PM   #15
Will the knuckles interchange?
Old 01-08-2009, 05:11 PM   #16
One thing I saw is the venoms outputs is in the center of the chassis, versus axial off set outputs.
werty is offline   Reply With Quote
Old 01-08-2009, 05:17 PM   #17
Just Zach's Avatar
Quite possibly, them measure out within .4mm of each other.
Agreed on that. With the widemouth chassis it will be super easy to mount stuff on the side of the tranny.
Old 01-08-2009, 09:38 PM   #18
Just Zach's Avatar
I wanted to show more build pics but I had to get this done today. I have a buddy that is going to test it at the Sin City comp this weekend.
I mounted the shocks next to the lower links on the axles and limited them quite a bit and they could use more limiting. I'm actually quite impressed with the kit overall. I've been a fan of internal and external springs on shafies for a long time now.
I need to look and see what Venom offers but I would like to get the differentials to lock and unlock with a servo.
Here what I like more on the Venom kit over the Axial, keep in mind that these are first impressions
Axles w/ CVD's stock
Drive shafts
Shocks
Wheels but that's just looks
Tires seem alright, I'll try them out soon but at least they look great
Rod ends seem better
What I like more about the ARTR kit more
Chassis
Tranny is WAY smaller
Lockouts on the rear axles
Proven strength
Either could be taken with a little bit of adjustments and be made into a real competitor.
Finished pics
Old 01-08-2009, 09:45 PM   #19
OCCUPY RCC!
dezfan's Avatar
Nice work, funny how a new rig gets you itchin to build something.
Looking forward to it's performance evaluation.
Old 01-08-2009, 09:56 PM   #20
Est. 2003
PinchFlat's Avatar
Not bad at all
PinchFlat is online now   Reply With Quote
