| | #1 |
| Pebble Pounder Join Date: Oct 2008 Location: N. CA near Tahoe
| Here are some photos of the wheels with the heavey weights on a scal. One wheel weight ![]() Wheel with all weights ![]() Wheel with weights an tire ![]() Next will be the axel wight with the rims and tires Front axel ![]() rear axel ![]() With of axel with factory rims and tires ![]() Tire HT ![]() Its done fine tune wires and 55T motor. The wheel base is 12.5??? Here is the total weight 8lbs 14 oz ![]() HT ![]() Front view Last edited by docfire; 01-09-2009 at 05:21 PM. Reason: Photos links |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Sep 2008 Location: Kennesaw
| Spill the beans, where did you get the weights from? |
| | #3 |
| From the Venom web site came in three days |
| | #4 |
| Newbie Join Date: Jan 2009 Location: Kelowna
| what, I ordered my creeper on the 31st and I can't wait any longer, when is this thing coming!!! |
| | #5 |
| Rock Crawler Join Date: Feb 2005 Location: Oxford, MA
| Docfire, is there really no way you can mount another brand of tire on this rim? |
| | #6 |
| The tire bead is diffrent more oval in shape unlike the square bead on other tires, and the venom tire bead is not as tall. Im sure you can make it work with a little trimming. I should have tried a losi tire before buidling the wheels. |
| | #7 |
| Quarry Creeper Join Date: Dec 2008 Location: Gold country
| Other tires do work. i put hb rovers on mine! |
| | #8 |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| Did you really pay $60+ for weights? |
| | #9 |
| Quarry Creeper Join Date: Jul 2008 Location: Over a rock and under a bridge
| I'm going to assume that the wheel weights are not Pb and is W (tungsten). Hence the asking price for a set. If you're wondering why tungsten is so expensive, it's because the USA does not produce any tungsten. It's all imported. How much did you pay for your weights? Last edited by zoojunkie; 01-14-2009 at 01:11 PM. |
| | #10 |
| Quarry Creeper Join Date: May 2006 Location: Pirkkala, Finland
| As far as I know the wheels weights are made of steel. Edit: I hope they were tungsten... ;) The russians use tungsten in ice-fishing lures called mormyshka and they are really heavy compared to their size Last edited by tomik; 01-14-2009 at 04:00 PM. |
| | #11 |
| Newbie Join Date: Oct 2008 Location: rancho cucamonga
| do the wheel wieghts help alot when crawling? |
| | #12 |
| They make center of gravity lower, so yes they do help. |
| | #13 |
| Grrr... Here we go again! ![]() Join Date: Mar 2010 Location: Colorado Springs, Co
| So what is the average weight of eack wheel on your creeper and what combination works best? Mine is about 13 oz in front and 7 oz in rear. That's the weight of the led, tire and rim. |
| Thread Tools | |
| Display Modes | |
