Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: sloppys creeper scaler
Old 02-01-2009, 09:42 PM   #1
sloppy's Avatar
Default sloppys creeper scaler
well I got my creeper today..
had a Xtrail laying on the shelf, few hours later and I allmost got this thing ready to run everything built up pretty easy, only issue I had was one of the CVD's outputs was to tight to get the bearings on. I removed the paint, still to tight took a file to it still damn tight but I got the bearings on, dont think they will ever come off but there on there...
tranny is pretty big on it, I had a axial trans laying there and really thought about going that route, but I figured I would go ahead and give it a shot..
fits between the rails pretty good.. need to drill a couple holes in the skid but should work out fine..
still need to figure out shocks. not sure if I will use the stock ones or something shorter..
my original plan was use this for a 1.9 and I still may go that route, but I wanted to see it with the stock 2.2 looks good.. possible body..
I am not sold on the links or the tranny skid thing.. the links are not very "scale" looking.. but I might as well give them a shot..
sloppy is offline   Reply With Quote
Old 02-01-2009, 10:13 PM   #2
Damn! looks good! and I dont meen the rig no really it will be cool to see a
scaler out of venom stuff.... I love my creeper so far.
1\4elliptic toy is offline   Reply With Quote
Old 02-03-2009, 10:34 AM   #3
What chassi is that
ktmkurt is offline   Reply With Quote
Old 02-03-2009, 10:40 AM   #4
sloppy's Avatar
it is a X-Trail..
Old 02-05-2009, 04:29 AM   #5
Cool Build....any updates? I really like the tires and wheels on it.
Sasquatchbagger is offline   Reply With Quote
Old 02-05-2009, 11:53 AM   #6
sloppy's Avatar
yeah I built the shocks and I will put them on somehow this weekend..
Old 02-08-2009, 09:33 PM   #7
09 RCA champ!
rednck21's Avatar
cool build! id like to see more pics of your work table cleaned off
rednck21 is offline   Reply With Quote
Old 02-08-2009, 09:43 PM   #8
sloppy's Avatar
i am using that table because the work table has gotten so bad, that I have temporally had to go on strike till someone cleans it up some..
Old 09-21-2009, 11:53 AM   #9
sloppy's Avatar
Well this thing was almost parted out I had it on the bench and was gonna pull the R2 trans out of it for something else. Then I realized all it needs is a RX and the lockers figured out.. So I got out the DX6 and started playing around..
First thing I found the cable lockers seem to really stink.. So I put the servo on the axle works good still needs some tweaking but it shifts in and out fine.. Ran a battery threw it after that with just the rear working and I really like it turns great.. Now I have to figure out the front locker.. I was really put off on figuring out the 6 channel radio but now that I have used it I may be switching some other stuff over to it to control is fantastic.
I also settled on a body and started the paint
inside the lexan paint done..
will start on body color tonight hopefully..
Old 09-22-2009, 01:53 AM   #10
sloppy's Avatar
starting to get some color on the body..
gonna go blue with white top.. maybe black hood..
front locker setup Works great I need a tiny lock nut and its done..
rear locker.. Works OK needs a couple linkage parts its binding a little as it sits..
I will shorten the rods up on both front and rear once I know there set and working good..
and a overall chassis shot 8-)
Old 09-22-2009, 01:31 PM   #11
I love the picture with Simpsons on the TV and chicks on the table....
But seriously Nice build, been thinking about doing the same thing.
krazy is offline   Reply With Quote
Old 09-23-2009, 02:30 PM   #12
Can you clean off the table?then retake the pictures.you can put the crawler under the table
Sicario666 is offline   Reply With Quote
Old 09-24-2009, 02:19 AM   #13
sloppy's Avatar
the simpsons great to build a truck during
umm NO
mounted winch and hid behind the grill.. it all tucks up real nice with the bolts tight
made a couple trays out of ABS for the battery and all the other crap.. up to 5 channels now
I wanted to mount the RX and all the stuff but the ESC on this top tray but with the body on the RX with all the wires plugged in wont fit so it will have to get mounted by the ESC..
Old 09-26-2009, 08:56 PM   #14
sloppy's Avatar
should get some action pics tomorrow
Old 09-26-2009, 11:59 PM   #15
looks awesome man
The_kernel114 is offline   Reply With Quote
Old 09-27-2009, 07:50 PM   #16
sloppy's Avatar
Originally Posted by The_kernel114 View Post
looks awesome man
Thank you
got to hit some trails with it super happy.. Gonna make some more changes and it should be sweet..
Old 09-27-2009, 08:52 PM   #17
how are the diffs working?
Old 09-28-2009, 02:11 PM   #18
sloppy's Avatar
Front works great.. rear I need to redo the linkage and it will be good to.. I didnt have enough parts to set the rear linkage up right now I do..
Old 11-21-2009, 08:05 PM   #19
Hey sloppy truck looks great. I got one question. Can you throw a set of 1.55's onto this truck for a picture if you have them???
mastathug0 is offline   Reply With Quote
Old 11-21-2009, 09:41 PM   #20
sloppy's Avatar
I am pretty sure 1.55's wont clear the knuckles on the axles..
