| | #1 |
| Quarry Creeper Join Date: Nov 2008 Location: St George
| Ok here is some tire comparison videos, same weight different tires/wheels EDIT: The weight is 1/2 lb per tire, all tires have holes in them and all tires are running the foams that came with them. First is the HB rovers http://www.youtube.com/watch?v=n4Ff8...e=channel_page Then the stock tires facing forward http://www.youtube.com/watch?v=cVo-j...e=channel_page Then the stock tires backwards http://www.youtube.com/watch?v=gZ6ss...e=channel_page Then the Losi carvers http://www.youtube.com/watch?v=4q8cm...eature=channel And then a fun run http://www.youtube.com/watch?v=5dkrT...e=channel_page Enjoy!! Last edited by 1\4elliptic toy; 02-03-2009 at 09:38 AM. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: May 2008 Location: Dayton
| I think the hb rovers was hands down the best choice I made on a upgrade for the creeper. |
| | #3 |
| Rock Stacker Join Date: Jan 2009 Location: Prescott Valley, AZ
| My first upgrade was the hb's plus some weights. Night and day difference from stock. They were working so good, I broke a pin in the front axle joint on the short side along with the C-joint. Now I'm down waiting for parts. |
| | #4 |
| Newbie Join Date: Jan 2009 Location: flag
| How much wieght??? |
| | #5 |
| 1/2 lb in each tire. |
| | #6 |
| Newbie Join Date: Jan 2009 Location: Paradise
| Nice comparison, did you have holes drilled in the wheels when you were running the stock tires? I drilled holes in my wheels and am running the tires backwards, it seems to do pretty good, but after seeing that i want to look into those hb's. |
| | #7 |
| Rock Crawler ![]() Join Date: Nov 2005 Location: dallas
| As soon as I put the Creepers to the table test and they made the Imex sound I tossed them to the scaler pile |
| | #8 |
| Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
| | #9 |
| Rock Stacker Join Date: Jan 2009 Location: Toronto
| What wheels were you running for the Rovers? Those are my next tires for sure, I just want to make sure I get the right wheels. I'd like to use the venom wheels as I like the look of them and the price is good, but I don't think the bead lock will work. |
| | #10 |
| Go to this thread, I run the stock Creeper wheels with the HB rovers and they work fine Some crawling pics |
| | #11 |
| Awesome. Thanks! Are you using the stock foams that the white rovers come with? :-P Last edited by bassguitar; 02-19-2009 at 03:11 PM. |
| | #12 |
| Well, partially. I put about a half inch of the hb foam at the rim, then use the stock memory foam from the creeper wheels on top of that. Works great. I also run 8.5oz of weight per front wheel. |
| | #13 |
| Rock Stacker Join Date: Feb 2009 Location: Oregonian liven in Utah
| I just got my HB Rovers (whites,soft) all mounted up today. They work great in the snow. I was really suprised how well the goofy tread pattern actually cleaned out in stick wet snow. I think they work better tackling obsticals side-ways at angles than head on. I should have maybe went with the Blues, Im more of an indoor crawler and the white's are supper mushey on carpet and couches |
| | #14 | |
| Quarry Creeper Join Date: Nov 2008 Location: Slovakia
Rovers are soft or medium? Thank you | |
| | #15 |
| I would say it's in the wheels. I think most guys around here would say don't put holes in the tires. If it catches on a rock or something it'll tear your tire apart and you don't want that do you? |
| | #16 |
| Team Hardkor Crawlers ![]() Join Date: Jul 2008 Location: appleton
| The stockers were ok for stockers the more time ran on them the better they worked but for a stock tire what can you expect i will be running them on the trail truck soon i also have tried several others panthers claws badlands and the chisselss the claws work best in the basement test course but the chissels worked great the panthers have so much bite they would barry them selves between the rocks snow is melting today so hopefully will bw outside crawling soon. |
| | #17 |
| bassguitar Sure, i just wanted to be sure what 1\4elliptic toy with his tires ;) kasper, do you know interpunctions are? Looks like word garbage :( |
| | #18 |
| | #19 |
| Thanks how big are those holes? do you have a photo, please? |
| | #20 |
| Here ya go Rim and Tire Venting Methods? |
| Thread Tools | |
| Display Modes | |
