Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: What motor are you running....
Old 02-09-2009, 05:41 PM   #1
Default What motor are you running....
I have the Venom 50t and it is a turd.... No wheel speed and no torque. Love the truck but man.. I have a sidewinder and Elite 1500 8 cells. What gearing and motor are you guys running.
88_Pathy is offline   Reply With Quote
Old 02-09-2009, 05:52 PM   #2
Stock gearing with a 18t Novak goat crawler system. Works awesome with lots of torque and crawling ability and wheel speed to boot. Right now I use a 7 cell 3000 mAh in the battery tray, but will soon be making my own batteries to mount up front to lower the COG.
RetVet is offline   Reply With Quote
Old 02-09-2009, 06:12 PM   #3
I use the stock gears, 55 turn Axial, with a 2cell 2200 lipo. Tons of torque and plenty of speed.
savageman46 is offline   Reply With Quote
Old 02-09-2009, 06:26 PM   #4
Integy 55 turn, stock gearing, 6-cell 3300mah nimh
lots of torque but not enough wheel speed for me, but I have a full set of pinions in the mail to fool around with.
I might pick up something around 17 turn, so i can set it up for bashing etc.
Stevek is offline   Reply With Quote
Old 02-09-2009, 07:00 PM   #5
I run this turnigy outrunner...its a monster for such a little motor!
It is about as big around as a quarter and about 1.25 inchs long
the torque is amazing!
http://images.google.com/imgres?imgu...3Doff%26sa%3DN
1\4elliptic toy is offline   Reply With Quote
Old 02-09-2009, 07:08 PM   #6
Sweet set ups.. Well I reprogrammed the sidewinder and updated the firmware.. Still having the same issues. It wont even crawl up the couch without full throttle. And the speed control just makes noise like it is struggling. I have a mx-3fhss receiver, and it will drop the throttle randomly.. The steering still will work but nothing else. Then the lights will act like it should be moving but no cigar.... Do I just have it set up wrong?
Old 02-09-2009, 07:44 PM   #7
I have the Novak Rooster crawler and the Novak 55 turn motor. My battery is a Li-po 11.1 1500 E-flight. Works great, tons of low power.
slvrf150fx4 is offline   Reply With Quote
Old 02-09-2009, 08:48 PM   #8
Wink
I run a tekin fx-r with the stock gears and a 45t tekin motor. I love it, lots of torque and good wheel speed. $100 combo
Check your throttle EPA settings on your radio. You can set them at 100% then reprogramm your speed control and go from there.
hoplesshunter is offline   Reply With Quote
Old 02-09-2009, 10:01 PM   #9
Same here except mine is a 55t motor, had I know it needed soft wear to fine tune it i probably wouldent have went with it.
hoplesshunter, You in Sunset Ut?
smashmetal is offline   Reply With Quote
Old 02-09-2009, 10:19 PM   #10
The are set to 140% on the receiver.
Old 02-09-2009, 10:34 PM   #11
Ya, sunset utah. You in this area? maybe go crawlin together?
Old 02-10-2009, 12:04 AM   #12
I am running a birdman 27t, moped esc, and 6.6v 2cell. 12t pinion, torque wheel speed and decent run times.
werty is offline   Reply With Quote
Old 02-11-2009, 12:26 PM   #13
60 turn motor... works great and it pulls and pushes me up the rocks....
http://rc4wdstore.com/product_info.p...roducts_id=689
that is it.... lol.
Old 02-12-2009, 11:53 AM   #14
I just got my Creeper all assembled & going!! It is my first crawler, but I've had other R/Cs for many years.
I chose the Trinity 65t motor and put in an old Novak Reactor ESC that I had. I have only gotten to run it a few times so far but it seems to have plenty of torque! It climbs up undercut ledges just fine. It is kinda slow just driving around or to the next obstacle, but that could probably be changed with gearing (still stock).
Love the Creeper so far!
stompercj5 is offline   Reply With Quote
Old 03-04-2009, 09:23 PM   #15
Revived the Creep... That Venom motor was bad... I put in a 35t integy w/ cut comm and it is awesome. Super happy with it. Now to fix the lockers.
Old 04-15-2009, 12:03 PM   #16
Question Pinion
Still waiting for all the pieces to get here, :-(
but I recieved the Novak Goat Crawler ESC with the 21.5 motor today
I have read that there is a 15 tooth pinion in the Creeper kit, can I use that one on this motor or should i get another one
thanks in advance
John Doe is offline   Reply With Quote
Old 04-15-2009, 05:41 PM   #17
Novak GOAT 18.5T equiv crawler system. 7.4v 4000mah 20c lipo and a 7.4v 4500mah 20c lipo. OEM gearing... good to go, so easy to control at low speed and mad power.
wangankin is offline   Reply With Quote
Old 04-16-2009, 08:54 AM   #18
Kyosho Lemans 600E (brushed, 15 years old, and as far as I can tell 27T), stock pinion, Novak Rooster Crawler, 7.2V.
It lacks some low speed control but it has enough torque to move along yet not break the drivetrain, and I get good power and wheelspeed when I need it. My friend got a Venom 55T and it lacks wheel speed to push itself over hard obstacles but has better low speed control.
I plan on getting a Holmes Puller 7T next winter with a Sidewinder ESC.
YJ_Driver is offline   Reply With Quote
Old 04-16-2009, 11:44 AM   #19
slvrf150fx4 - "I have the Novak Rooster crawler and the Novak 55 turn motor. My battery is a Li-po 11.1 1500 E-flight. Works great, tons of low power."
Running the same setup and very pleased, tons of low end! I have the 2s 7.4v 1250mah li-po and can run 45+mins.
slvrf150fx4, how do you have the 11.1 volt pack setup? I looked at running the 11.1v 3s packs, because I have a few from my planes, but the novak rooster crawler is only rated for a 2s lipo.
T
Dark8ngel is offline   Reply With Quote
Old 04-16-2009, 12:34 PM   #20
45+ minutes... wow no wonder iget bored i have an 1800 in mine.... haha
paintz2007 is offline   Reply With Quote
