| | #1 |
| Quarry Creeper Join Date: Nov 2008 Location: St George
| We took out both of the creepers today, We ran a full battery pack (3 plus hours) through both of them and were VERY hard on them.....and no broken parts!! Well almost Here is a shot that I drove into (on accident) and drove out of! I slamed it into reverse and it dropped off and landed on the tires and kept on running Very good day for the creepers! |
| Sponsored Links | |
| | #2 |
| OCCUPY RCC! ![]() Join Date: Dec 2005 Location: I am the 53%.
| Good to hear, I think we are slowly weeding the issues out and getting them corrected. |
| | #3 |
| Rock Stacker Join Date: Jan 2009 Location: Eagle, Idaho
| NICE!! That is a pretty sweet shot right there! |
| | #4 | |
On a side note I have pulled the locker twice now and have yet to see any real wear on the nylon washer that holds my locker in place, I have not seen any slipping what so ever with the locker ethier. | |
| | #5 |
| I couldnt believe that when it happened, I was side hilling the opposite direction when the driver rear tire slipped off the ledge and drug the whole thing off the ledge, it swung around on the tire and just hung there, So I took a picture and then grabbed reverse |
| | #6 |
| Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
| Yea that doesn't look like a fun spot to crawl at all. Yeah right! Keep crawlin |
| | #7 |
| Team Hardkor Crawlers ![]() Join Date: Jul 2008 Location: appleton
| nothing is perfect out of the box i pounded mine on sunday for a good hour and held up well still some tweaking to do but its a nice rig too many give up on them to quick where would we be if they did the same with the other crawlers.I have almost one or more of everything and they all serve there purpose |
| | #8 |
| Newbie Join Date: Oct 2007 Location: St. Louis
| Thats amazing, I'm so jealous you have that to dive on. I have nothing like that here in the midwest. |
| | #9 |
| Newbie Join Date: Jan 2008 Location: dublin
| Sweet I'm glad to hear a report like this because I just ordered mine the other day. It was a hard decission to go with this rig. I have noticed in some videos that it seems to lift the right front wheel while climbing steep inclines is this the way this rig handles or is it due to poor setup. |
| | #10 |
| most likely poor setup. I can stick mine up a 70 degree angle with all four wheels on the ground. Then again i run a droop setup. Go to the venom creeper picture thread and look at my setuip, (and others) and you can get an idea what it takes to get rida the torque twist. One thing that i think got rid of alot of toarq twist was running my upper 4 links outboard. |
| | #11 |
| Rock Stacker Join Date: Feb 2009 Location: Oregonian liven in Utah
| 1\4elliptic toy, My HB rovers just showed up today I'm wondering if the memory foam that came the creeper would be good in the Rovers. |
| | #12 |
| Rock Stacker Join Date: Jan 2009 Location: Prescott Valley, AZ
| I run the hb's also. I run the memory foam from the stock tires in them, plus a little of the foam from the hb's on the inside of the memory foam. If you run just the memory foam from the stock tires, it leaves a void in the tire and it looks like you are running on flat tires, plus you won't really realize the benefit of the oversize tires if you run just the memory foam because it will sit so low. I added about a half inch from the hb foams to the inside of the stock memory foams to take up the void. |
| | #13 |
| i am running the stock foams with a small ring of memory around that, I might beef up the sidewall too with a half ring of memory...remember I am running a full pound in each front tire though. |
| | #14 |
| Newbie Join Date: Feb 2009 Location: Colorado Springs
| yea great pic and setup, i did a few little things to mine and it crawls better than almost everyone i run with, i just got the rock claws for mine and i run a pound to a pound and a half in the front i cant quite remember but its a great setup, i snapped an axle shaft yesterday and just like everyone else venom jumped on it to hook me up, thanks venom |
| | #15 |
| speaking of breaking shafts, i just broke a driveline in my rock garden, the pin was coming undone and i didnt notice :( Do any of you know where i could get a set of drive lines? Every place i look says out of stock, late march.. :/ Maybe VENOM could hook a brother up with a set |
| | #16 |
| Im running the traxxas drivelines, we broke all 4 of the creeper ones, These are a simple upgrade. |
| | #17 |
| but i would have to buy the metal yokes for the traxxas, and thats not cheap.. :/ Im trying to get my hands on mip metal drivelines from thundertech.com But as the time be, they dont have any that i could get from them, and idk what to do now.:neutral: |
| | #18 | |
True, but mips are waaaay more than you will ever need, You wont have any issues with the traxxas stuff, and they are cheaper than mip's | |
| | #19 |
| Did you guys boil your drive shafts? Were are they failing. |
| | #20 |
| My failures have all been in the metal parts, not anything plastic, My thoughts are that several of the steel parts got over heat treated, not just the axles and the drive pins. The breakage in the drivelines were all under normal use, nothing hardcore just normal wheeling. |
| Thread Tools | |
| Display Modes | |
