| | #1 |
| Rock Stacker Join Date: Feb 2009 Location: Sunset, Utah
| Hey guys I just bought some panthers for my creeper (LHS didn't have rovers) and I mounted them up on my creeper wheels, but they keep falling of the beed. Am I doing somthing wrong or is there a trick or can you only run the venom tires on the creepers wheels? |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Nov 2008 Location: St George
| They should work, Explain how you mounted them... You should have made sure the tire was tucked in to the slot in the wheel then tighten the screws at "12" and '6" then "3" and "9" then fill in the others, make sure you tighten them snug. if it dont work......time for new beadlocks! |
| | #3 |
| I made sure that they were in the groove, but I didn't thighten the way you said. I just went in a circle. Thats probly my problem. Thats |
| | #4 |
| Pebble Pounder Join Date: Feb 2008 Location: on the edge of sanity
| NO NO NO NO silly, venom creeper rims are for a special type of bead, man come on, can you not see the difference in the beed on the tires go down and look at the bead man, it dont even look the same,, i dont even thing venom has any different tires for that rim yet, but no they wont hold, just need to get a new set of rims, should be able to get set for around 30 bucks for 4 if you price around |
| | #5 | |
Ummmm No.......You Fail.. Many of us are running stock creeper rims with other tires....Nice try though Look here: http://www.youtube.com/watch?v=utA0_5ERC6c Last edited by 1\4elliptic toy; 02-19-2009 at 03:51 PM. | |
| | #6 |
| Rock Stacker Join Date: Jan 2009 Location: Eagle, Idaho
| hahaha lizard017 do you even have a creeper? |
| | #7 |
| Newbie Join Date: Jan 2009 Location: Kelowna
| hahahaa ziiiing |
| | #8 |
| I have seen plenty of creeper wheels with different tires, so I know it can be done. I just thought you guys were maybe glueing them on which would be a waste of the beadlock. Thanks for the input from the guys that have the creeper. |
| | #9 |
| Also are the panthers good or should I have waited for the rovers? I toke the memory foam out of the panhers and put a harder black foam in them because thats what the guy from the LHS said would work best. And yes I am a newbie at the crawling world. |
| | #10 |
| I would have got the rovers myself, the pnthers are a pretty good tire....but its not a rover |
| | #11 |
| ok, the dam bead is so dam different how without glueing do they hold, got a machine to melt and make the bead match that of the creeper tires, its just not logical, well, sry, and no but i had talked to someone that had one and they said they talked to the manufacture and they said it had to have that special bead, so sorry i was given bad info, sry sry sry,,, ok im a dunce i got it |
| | #12 |
| HAHA Its all in fun man! Just busting your balls a bit.... We know they "are not" susposed to fit but they do, It just squishes the bead in there...who cares if it "fits" if it dont slip it works. |
| | #13 |
| 1/4 elliptic thanks for the info;). I put them on how you said and have been crawling on my course here at the house for about an hour and no slip and no pulling off the rim. Panthers are alot better then the stock, but it sounds like I should have waited for the rovers |
| | #14 |
| Rock Stacker Join Date: Feb 2009 Location: Oregonian liven in Utah
| Reading material for ya. HB Rover Review TCS has them on sale too! http://www.tcscrawlers.com/ON-SALE-5...2-p-17154.html |
| | #15 |
| Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
| Well... I just finished up what I can before I contact customer support so I can finish my creeper build... anyway back on topic. I ordered the rovers along with the creeper... they WILL fit creeper beadlox's... more of a pain in the ass than its worth installing them if ya ask me...after i did one I said F it and just mounted the stockers for now... I'll get some after market rims for the rovers... I planed that anyway so no biggie to me |
| | #16 | |
| OCCUPY RCC! ![]() Join Date: Dec 2005 Location: I am the 53%.
The Rovers are a good tire, but don't sell the Panther short. As for the mounting issue, I mounted Panthers on my Creeper wheels w/o issue and they hold the bead just fine. | |
| | #17 |
| Rock Crawler Join Date: Apr 2005 Location: Upland
| I'm guiding one now and noticed the bead is definitely different. I'm sore some tires will fit and hold even if the rim technically isn't made for them. |
| | #18 |
| Rock Stacker Join Date: Oct 2008 Location: Sacramento
| I've mounted Flat Irons on mine without too much difficulty. |
| | #19 |
| Quarry Creeper Join Date: Jun 2008 Location: Ironton
| yea... just leave them alone or get some new rims... the rims are one off style. so different rims are going to be a challenge..... i think alum weights make the suspension a little better, more weight. |
| | #20 | |
| Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
I wound up moving those rods in front of the axle so thats a non issue with how its setup now. | |
| Thread Tools | |
| Display Modes | |
