Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: Creeper on the rocks...FINALLY!
Old 02-22-2009, 09:55 PM   #1
JSN
Default Creeper on the rocks...FINALLY!
Well I finally got out to put the creeper through its paces... that lasted about 3 maybe 4 min before i bound up the front a LITTLE and snapped the front drive shaft off at the trans knuckle I sure hope Venom solves this over hardened parts issue. like a dumb ass i left my spare parts and pede joints/sliders at home... i was planing on taking it easy and just testing how it handled... silly me I decided screw it and ran in RWD only... the dam thing did GREAT! I spent almost two hours crawling the red rocks and made it more places than I figure i could... not to shabby for a 2WD! I did unlock the front diff to help keep the front end from pushing the rear around ... I put all the power 3s and my 35T could dish out on the rearend and it took it... NEVER UNLOCKED ONCE EITHER!!! driving out the pins on the red diff ring seems to have solved the unlocking issue for me.
I really like the way this truck handles and crawls...even in 2WD I have the pede shafts on now so tomrrow after work i'm going back out(with spares) to see how much better it does with all 4 turning and burning
JSN is offline   Reply With Quote
Old 02-23-2009, 12:01 AM   #2
Vegas huh? Did you go out to the comp today? I almost drove down but felt lazy instead
1\4elliptic toy is offline   Reply With Quote
Old 02-23-2009, 08:13 PM   #3
JSN
I didn"t even know there was a comp... oh well...maybe next time. I went back out crawling today... pede sliders in place... NOTHING BROKE!(of coarse not... i had EVERY spare part i have with me) spent 3 hours crawling with not one issue. I need to do some set up work and get some rims for my rovers... I think a little lower CG and more traction will make the creeper nearly unstoppable for me needs.
Old 02-23-2009, 10:34 PM   #4
The rovers work on the stock wheels...
88_Pathy is offline   Reply With Quote
Old 02-23-2009, 10:44 PM   #5
JSN
yeah i know... NOW. I tried installing the rovers during my build and wasen't having much luck because the bead kept slipping out of the grove... once again i was making a simple task WAY to complicated...I'm good for that at times. tonight i decided to add some weight and after i pulled the first stock tire i decided what the hell I'll try the rovers again... slapped the tire on the rim... lined up the beadlock ring and bolted the ****ers together I added 6oz to each front and 3oz to each rear...and of course the rovers... I'll see how this works and add more wieght as needed.
