Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Venom Creeper
Thread: Tranny Plug=Bads News!
Old 02-24-2009, 09:12 PM   #1
JSN
I just knew this would happen by how easy the plug was to pop out... I took a piece of 1/16 or so rod, heated it cherry red and burned a small hole into the tranny plug... a short piece of 20lbs test fishing line attached through the hole in the plug and one of the chassis holes secures the plug to the chassis so i won't loose it and it can't get into the gears;). just make sure you keep the fishing line or what ever you use as SHORT as possible so it don't get hung up on stuff.
Why is my response above your post??????
JSN is offline   Reply With Quote
Old 02-24-2009, 09:37 PM   #2
Originally Posted by hoplesshunter View Post
Just something to watch out for guys. I lost my tranny plug, but somehow it ended up in the tranny. It got all wound up in the gears and stripped one of the gears. Just something to watch for. I will not be useing the plug anymore, but will take a peice of electrical tape and cover the hole.
the first time out my'n did that. I found the motor was sucking the plug in.
I am using a different motor and it has not done it since.
Last edited by werty; 02-24-2009 at 09:38 PM. Reason: wow this thread is weird im in the middle
werty is offline   Reply With Quote
Old 02-25-2009, 09:03 PM   #3
Default Tranny Plug=Bads News!
hoplesshunter is offline   Reply With Quote
Old 02-25-2009, 10:41 PM   #4
WOW you guy a magic. How did you get your post above mine?
Werty what would cause my motor to suck it in?
Thats a good idea about the fishing line
