03-10-2009, 05:18 PM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: Slovakia
| Spur Gear / Pinion
Ok, we have 45T Spur Gear - http://www.venom-group.com/itemdesc.asp?ic=VEN-8343&tp= Where to get other (saw a gear ratio table)? And regarding pinion gear, what is the pitch of these spur. Wish to experiment with some ratio. Thak you |
03-10-2009, 06:15 PM | #2 |
Rock Stacker Join Date: Feb 2009 Location: Sunset, Utah
I couldn't find any other spur gears either:-( As far as the pinion goes I beleive it's a 15t 48 pitch (someone correct me if I am wrong). I switched to a 12t pinion with a 45 turn motor and like it alot. |
03-12-2009, 05:35 AM | #3 |
so you are usin' 48pitch gear, and it fits well? then it should be 48pitch
02-04-2010, 03:46 AM | #4 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
So has anyone found the Option Spur Gears???
02-04-2010, 08:09 AM | #5 |
Rock Stacker Join Date: Aug 2009 Location: Denmark
| I got mine at CML link: http://www.shopatron.com/home/search...+gear&x=27&y=9 |
