08-25-2009, 05:29 PM | #1 |
Quarry Creeper Join Date: Jul 2009 Location: St. Charles
| Behind the axle steering (BTA)
did the mod today and it works great. thanks for all the info on this site and other members. btw i used a stock lower link from the venom, cut it and tap it, and bend it some more here and there until it cleared the shock and the upper links. any questions just shoot me a pm. later. |
08-25-2009, 08:14 PM | #2 |
Pebble Pounder Join Date: May 2009 Location: South Gap
looks good I'm going do this mod one of these days. Whats going on with the chains? Does that limit your amount of articulation? |
08-25-2009, 08:34 PM | #3 |
Newbie Join Date: Jul 2009 Location: Phoenix
i did the mod a couple days ago also. works beautifully. i just used a upper link clears everything perfectly the extra clearance in the front makes a huge difference. i also cut off the screw post off both front and rear axles makes everything smoother. also id get rid of the skid if ya have some extra nuts available. less hang up.
08-25-2009, 10:24 PM | #4 |
yeah i'm planning on getting rid of the skid, that is what actually gets me stock a lot of times. i don't know what screws post you are talking about, the ones that you said you cut? pic? thanks. |
08-25-2009, 10:28 PM | #5 | |
more than enough flex... Last edited by ozpall; 09-02-2009 at 10:30 AM. | |
08-25-2009, 11:25 PM | #6 |
08-25-2009, 11:41 PM | #7 |
ahhh see pics are better than words, thx for the pic.
08-26-2009, 08:41 AM | #8 | |
That makes sense.. i was just wondering if you were doing it for the purpose of limiting your flex. I know too much can be a bad thing. | |
09-04-2009, 08:23 PM | #9 |
| crappy pic
here is the cover that i made today for the servo as it was taking a beating, crappy pic but you can see how and what it looks like. |
09-04-2009, 08:30 PM | #10 |
as an update, i gotta say that i love this mod, now with the plate covering the servo i can literally beat on it, more clearance, turning radious is great, the tires stop about 2mm from the lower links, it turns like i have no locker really smooth and sharp. i will definately recommend people to try this mod, fairly easy, no crazy spending cash and all with great results. i also changed my tires as you can see in the pic and it is 100% percent better too. later. |
05-02-2010, 01:28 AM | #11 |
Rock Stacker Join Date: Mar 2010 Location: Meridian
Is there anyone with the stock chassis that has this DIY BTA steering that would like to share pictures?! Ive been working on mine for a couple hours now and I cant seem to achieve enough clearance between (lets say) the left front shock and the steering link. Under load it limits the shock absorption and restricts articulation. I was just hoping some one had done this mod with positive results and would share clear and concise pictures for those of trying this! Thx, Brando \m/ |
10-05-2014, 08:22 PM | #12 |
Rock Stacker Join Date: Oct 2014 Location: New zealand
| Re: Behind the axle steering (BTA)
Yeah, i had the same issue, except with the front right shock(i was doing it on that side rather than left). I am also using a custom chassis, but with the shocks in more or less the same position as stock. What i did was i bought some M3 stainless rod, cut the right length and just bent it till it worked. The stock links, even if bent, are just to big diameter sometimes. I think the rod will eventually break, but my servo horn has just stripped and im looking for another. I hope this works for you. Sorry, im not yet sure how to add images, could you help me with that? Thanks
10-06-2014, 02:18 AM | #13 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Behind the axle steering (BTA) |
