01-31-2010, 05:19 AM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: brooklyn
| STAGE 2 cross brace length ?
What is the cross brace length for the stage 2 kit ??? I need the correct length to finish up my rig !!! |
01-31-2010, 05:52 AM | #2 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
By cross brace do you mean the one spanning the two chassis plates that take the place of the battery tray?????
01-31-2010, 06:05 AM | #3 |
The two aluminum braces running across the top in this picture are 80mm wide....They are made from .5" x .125" flat aluminum......I hope this helps |
01-31-2010, 06:49 AM | #4 |
| yeah the 2 tubes used to replace the battery tray !!!!
WHAT's THEIR LENGTH ????
01-31-2010, 07:59 AM | #5 |
Quarry Creeper Join Date: Sep 2007 Location: detroit
80 mm! But you can't go straight across on the fron! The motor is in the way. CKRC must give out a "U" shaped bracket that makes the span but clears the motor either over the top or in front, over the top wouldbe the best I think. |
01-31-2010, 09:29 AM | #6 |
| THANKS!! I CAN'T LOCATE 80mm links !!!
Where do i look or can someone post a link !!!! I checked ckrc and ebay !!! No matches im lost ! Help!!!!!
01-31-2010, 11:37 AM | #7 |
Rock Stacker Join Date: Dec 2009 Location: west monroe
| U said you ordered losi arms well tht won't help u unless u run 70mm uper links and then use ur old links fo the brace but brace it where ur shocks go Like I did thats the stock uper link braseing the chassis and new 70mm lover links it's off of the ckrc stage to with my on tweaks
01-31-2010, 12:02 PM | #8 | |
I'm not sure if it'll help,but you might find something to work here. RCP Crawlers Suspension Links and Spacers. There's nothing that's exactly 80mm,but you might find something there to use. Either a combination of 2 or a 74.5mm with a small washer on either side. Hope that helps. | |
01-31-2010, 12:34 PM | #9 |
| Oh ok !!!
thanks alot
01-31-2010, 03:12 PM | #10 | |
Quarry Creeper Join Date: Jan 2010 Location: north phoenix
01-31-2010, 03:24 PM | #11 |
| its a losi suspension arm for losi 1/10 comp crawler
its an excellent repllacement for the battery tray shock mount !!I think its best to mount them horizontal !!! |
01-31-2010, 03:27 PM | #12 |
| It's the piece connected to the shock in the picture up top!!!
the one in the pic is mounted vertical !!!
01-31-2010, 03:45 PM | #13 |
Quarry Creeper Join Date: Dec 2008 Location: Deltona, FL
I was just going to post any ideas to make something to clear the motor for the front mount.
01-31-2010, 05:15 PM | #14 |
Rock Stacker Join Date: Oct 2009 Location: beaverfalls
