Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Venom Creeper
Thread: what mods would be the best
Old 02-02-2010, 10:55 PM   #1
Default what mods would be the best
i have a stock creeper. i am going to start doing comps with it and i am new to the sceen. what mods should i start with ? i am running a novak 55t motor with axial esc, traxxas 4ch reciver, a cheepy all metal servo, drilled rims, cut foam, cut stock tires
ncrc is offline   Reply With Quote
Old 02-02-2010, 11:27 PM   #2
Probably a stage 2 suspension set up you can buy one at ckrccrawlers.com or just fab one yourself and you can also flip your lower links gives it more clearance and that's basically all I've done to my creeper besides adding some white rovers and put 10oz in the front and 6oz in the rear and I love the way it crawls now
mpjl95 is offline   Reply With Quote
Old 02-02-2010, 11:28 PM   #3
get some better tires and foams
hende is offline   Reply With Quote
Old 02-02-2010, 11:29 PM   #4
by flip the lower links does it do i need to position them so the "s" shap is verticle ?
Old 02-03-2010, 12:00 AM   #5
which tires are best to run with the creepers ?
Old 02-03-2010, 12:25 AM   #6
It is generaly seen as swapping them end for end. This is you take a lower link out and turn it round and fire it back in.
I did not bother with that and ran them flat so that the "S" is layed flat to the ground.
I then straightened them all and love it.
70mm uppers and 99% of the twist is gone.
Most people will tell you Rovers are the go.
Learn to set up your crawler and adjust the suspension etc before you rush out and buy new rubber.
I have hacked and cut at the stock tires and now have a set of hacked and cut Lizzards. These less than perfect tires are great for me as I get to see each minor tweak that I make in the suspension setup.
My mates CK with Grabbers is left on its lid on most climbs.
Rubber is good.
Setup is better.
Simon.O. is offline   Reply With Quote
Old 02-03-2010, 04:21 AM   #7
I would say FLM lockers and Junfac driveshafts is the biggest thing that needs improvement on the creeper.
JUSTGOINGSLOW is offline   Reply With Quote
Old 02-03-2010, 06:10 AM   #8
My most noticeable change was getting the battery off the top and White Rovers..... I also did FLM lockers and a homebrew stage 2 with losi shocks but tires and lowering the battery would be top on my list.
Captaincrash is offline   Reply With Quote
Old 02-03-2010, 06:46 AM   #9
HB Rovers and Stage 2 suspension
evolekim is offline   Reply With Quote
Old 02-03-2010, 11:39 AM   #10
smr
I just started crawling with mine and the Rovers are a must. I'm running my rovers with the stock Venom foam and they have to much traction...I am also rocking the CKRC stage II kit and I am out crawling a LCC and an AXIAL with comparable mods.
smr is offline   Reply With Quote
Old 02-03-2010, 03:00 PM   #11
ok sounds good guys i will start ckrc kit and go from there
Old 02-03-2010, 03:12 PM   #12
A rooster or a tekin ESC, rovers, 70MM uppers, a better servo, weight in the rims, 2S lipo, take that battery tray off and dro pit down, get some firmer springs too.
madmax22 is offline   Reply With Quote
Old 02-03-2010, 04:03 PM   #13
Stage II suspension, weight the front at about 6-7 oz each front, lower the battery for sure, Im running a 2 cell lipo 2200 mah pack on the rear axle, get baout an hour run time with my navak Goat 2s brushless system...
Tires??? I like the panther leopards!! with soft memory foam on a 1 inch wide Vanquish SLW...and definately a 250 oz plus steering servo...Dig unit really is nice too....I used 2 paisr of 7 dollar steel traxxas links for my lower links and bent them myself...Created a lot of extra clearance...FLM lockers for sure and some traxxas steel yokes with traxxas drive shafts....no problems yet!!
crawlercop is offline   Reply With Quote
Old 02-03-2010, 09:38 PM   #14
i got punisher shafts, better rubber, flm lockers and i don't know what else.
ozpall is offline   Reply With Quote
Old 02-03-2010, 10:43 PM   #15
on my comp creeper i'm running, white rovers,12oz front, 6oz rear, FLM lockers, FLM hardend outers, FLM shock bodies, CKRC stage 2, punisher shafts, venom dig, novak goat 3 brushless on 11.1, nova's tire foam, and more
n0b420 is offline   Reply With Quote
Old 02-04-2010, 09:02 AM   #16
If your just getting into it A new set of rovers or sedonas are going to go further than the ckrc suspension kit, which in my opinion is lacking anyway. And if you intend on competing a dig unit is a must.
"N8" is offline   Reply With Quote
