03-11-2010, 12:11 PM | #1 |
Rock Stacker Join Date: Feb 2010 Location: Riverton
| Help with build?
Hey guys....Im having trouble with the gears of this creeper. The are PRETTY HARD to turn them. Is that normal? They are greased plenty and seemed to be turning fine before I closed the box. I would open it back up but a few of the hexes are stripped. Any help? |
03-11-2010, 12:14 PM | #2 |
Quarry Creeper Join Date: Feb 2010 Location: muskegon
The gears are hard to turn by hand but once you get a motor on it they'll turn just fine under power i had the same concern don't worry |
03-11-2010, 12:17 PM | #3 | |
Everything is good? My buddies AX10 turns easily by hand. | |
03-11-2010, 12:18 PM | #4 |
yup mine did the same thing. is this your first kit?
03-11-2010, 12:18 PM | #5 |
03-11-2010, 12:21 PM | #6 |
Yeah i felt the same way with my first kit you get used to it around the third or fourth one. so what you running with? so far that is
03-12-2010, 06:30 PM | #7 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
diffence is the axial tranny has 3 gears inside. The venom trans has like 10. All that mesh is gonna make it hard to turn by hand by the output shaft. Stick a driveshaft on it and then turn it. It should move easier then cause you'll have more to grab on to.
03-12-2010, 10:47 PM | #8 |
Ya...it was nearly impossible to turn by hand and now after a short warmup run its now runnin AMAZING!!! Thanks for the calming advice fellas. Hope this thread also helps other noobs like me in the future! |
